How to line up 3x3 kluson style tuners
Discussion in 'Tele-Technical' started by sleazy pot pie, Jul 28, 2021.
  1. sleazy pot pie
    sleazy pot pie Tele-Afflicted Gold Supporter
    austin
    I am having a hard time figuring out how to line up a set of kluson style tuners on a 3x3 headstock.
    The holes for the posts are not in a straight line, but on a bit of an arc.
    4E4C2B4F-AC5B-439A-9876-3540E3F14C42.jpeg 600653F0-EB0E-4EF7-B4AA-91A17D1ADB9F.jpeg 088D54C3-3E32-4DF0-AECF-E800A5BAF1E4.jpeg
    is there a trick to getting these to look good?
    On a side note, I finally got a neck amber mix that I like, and dropped the neck on concrete, messing up the corner.
    Boreas likes this.
  2. Freeman Keller
    On a head with curved sides like that I usually line them up with the side
    With straight sides I lay a straight edge next to them.
    sleazy pot pie and Boreas like this.
  3. Peegoo
    Peegoo Poster Extraordinaire
    Challenging Definitions of Sin
    I install them so the button shafts are 90 degrees in relation to the edge of the headstock. Which means three on one side are all a little bit misaligned with their neighbors. But it looks balanced and provides equal finger room all the way around the button.
    PRS installs theirs straight across; i.e., the button shafts for the tuners are all parallel in relation to one another.
  4. Boreas
    Boreas Poster Extraordinaire Silver Supporter
    Adirondack Coast, NY
    Personally, I like all of the shafts being parallel, which means you would line the backs up to be parallel with a straightedge. But feel free to do as you wish.
    teleplayr likes this.
  5. sleazy pot pie
    austin
    Cool, thanks guys. this project is nothing but firsts for me.
    First 3x3 headstock, first wraparound bridge, first filtertrons, first 24.75 scale.
    Thanks for the help.
    Boreas likes this.
  6. sleazy pot pie
    austin
    min not following you on the shafts lining up.
    How would I go about doing this? The headstock is already drilled for the posts.
    Maybe I am misunderstanding what you mean.
    Boreas likes this.
  7. Boreas
    Your 3rd picture shows the bottom 4 tuners pretty well lined up with the straightedge, but the top two are twisted outward slightly. That makes the tuning shafts look crooked when viewed from the front.
    Basically, take that straightedge and make sure it is centered between the tuners. Or you could draw a line down the exact center of the peghead. Then, make sure the top and bottom corner of each plate are equidistant from the straightedge or line. At that point, all the tuner shafts should be parallel.
    sleazy pot pie likes this.
  8. Freeman Keller
    You're gonna love it.
  9. backporchmusic
    backporchmusic Poster Extraordinaire
    You've got the tuners on the wrong side of the head. With the guitar standing neck up, the keys should sit above the gear mechanism. Now as far as getting them to line up perfectly...no ideas.
  10. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    In other words...shafts parallel to the nut.
    Boreas likes this.
  11. sleazy pot pie
    austin
    sure wish I had read this sooner.
    I drilled one hole for each tuner already.
    this place is great, so many helpful people.
  12. sleazy pot pie
    austin
    Well, off to the store for toothpicks.
    But, I have got it figured out now, so the tough part is over.
    big thanks to back porch music for catching this for me.
    backporchmusic likes this.
