How to get rid of brown rusty spots on soldering iron tip
Discussion in 'Shock Brother's DIY Amps' started by itsGiusto, Nov 2, 2019.
Tags:
  1. Telegnosis
    Telegnosis Tele-Meister
    Third Rock
    You need this using it while you solder and specially after you get done before you turn the iron off. Leave it tinned.
    Amazon sells a lot of the different brands and kits.
    Use this brass wool ball and jab the tip in there several times often while soldering.
    Forget the wet sponge. The wool ball is all you'll need.
    You can also buy stainless steel balls you find to clean pots and pans to bolster the brass ball that comes with these ball holders. This way you don't have to dig in there with the iron tip if they don't give you enough wool.
    BobSmith and jtcnj like this.
  2. Wally
    I use a Velleman desoldering mesh. The mesh ball can be pulled out of the cup so that the old bits of solder can be dumped..and the mesh ball, rubbed around, cleaned, and reformed. I saw another brand that does the same thing. Just google Velleman desoldering mesh and you will get to that and other options. There is a similar one with a stand....they are on eBay...and elsewhere, I am sure. I have no affiliation with any company, but I would want to have a unit that allowed the mesh to be pulled out and cleaned.
  3. corliss1
    Lansing, MI
    The brass wool/mesh/whatever you want to call it is superior to water in every possible way.
    Good iron, keeping it tinned, and using the mesh makes tips last far longer than any wet cleaning.
    By the time you get rusty spots, that tip needs to go, in my experience. With care, my tips seem to last until they get so heat stressed they eventually break in half.
  4. raito
    raito Poster Extraordinaire
    Madison, WI
    I use the mesh while working. Before I stop, I use the sponge followed by retinning. That way my tip is always bright when I start again.
  5. jtcnj
    jtcnj Tele-Holic
    Brick, N.J. USA
    +1 on the cheapy $30. solder station on Amazon; I have used mine the last few years through several builds now.
    Run through the brass mesh after every joint; tin before every joint and when shutting down.
    Tip stays clean.
    The key is to prevent that tip from starting to pit.
  6. PCollen
    PCollen Friend of Leo's Silver Supporter
    Man of the World
    I have a Ungar 777 handle with a 1237s 42 watt element That I
    I've used for 40 years and NEVER have cleaned. Just wipe it on the sponge after use before it cools. Of course, I rarely solder anything , but it's still functional.
    rangercaster likes this.
  7. schmee
    Best to use a dagger instead of the iron....
  8. itsGiusto
    itsGiusto Tele-Meister
    Massachusetts
    On the Amazon page, they say this is for plumbing work, not electrical soldering. I think someone previously mentioned in this thread that this plumbing paste is corrosive to electrical soldering irons?
    Thanks, I ordered some of this stuff, but I'm not sure how to use it! Could you help me out?
    It doesn't really look like a paste inside the can, but more like a hard tab. How does it work exactly? I can't even really rub my soldering iron on it, cause the angle of the can won't allow me to really rub it around on all sides.
  9. Art VanDelay
    Art VanDelay Tele-Afflicted
    Arcata
    You're right that it is intended for joining copper pipes, but I've had no issues like corrosion or oxidation. I'm out of my depth here on knowledge so maybe somebody "in the know" can give you a conclusive answer.
  10. dan40
    dan40 Tele-Afflicted
    Richmond Va
    You can get away with using acid core flux on the iron's tip because it won't stay on there for long before it wears away. You would not want to use it on electrical connections though because it will corrode the joint over time. I am a plumber by trade and we always wipe away the flux completely after soldering a copper joint. If not, the joint corrodes and turns green within a few days.
    itsGiusto likes this.
  11. itsGiusto
    Massachusetts
    Is this stuff acid-core flux?
    https://www.amazon.com/dp/B001B0A3OQ/?tag=tdpri-20
  12. dan40
    Richmond Va
    It list in their technical specs that it should not be used on electrical connections so it likely is acid core. It is the same tinning flux that we use on large diameter copper pipe. It would still be okay to use on your tip though because you are constantly cleaning the tip during the soldering process.
  13. dan40
    Richmond Va
  14. Boreas
    Boreas TDPRI Member
    Port Kent, NY
    "Thanks, I ordered some of this stuff, but I'm not sure how to use it! Could you help me out?
    It doesn't really look like a paste inside the can, but more like a hard tab. How does it work exactly? I can't even really rub my soldering iron on it, cause the angle of the can won't allow me to really rub it around on all sides."
    Is your can really shallow? Perhaps yours is in a different type of can. I assume you are using it with a HOT iron - correct? Mine is quite shallow and easy to use. The hot iron melts the hard material. I just tin the tip with it, not the entire iron end. I either plunge it or roll it around, then remove any excess with a brass wool ball noted above.
  15. Boreas
    Boreas TDPRI Member
    Port Kent, NY
    Very good advice!!
  16. itsGiusto
    Massachusetts
    Thanks, I eventually figured it out. Though I still may not be using it right. After a session of using it, my tip looks kinda scuffed and dirty.
    For now, I'm using that acid core plumbing flux, since that really does always leave my tip looking like a mirror.
  17. Wally
    That acid flux is not something I would use as it is likely to cause deterioration of the tip. One should use resin core solder and resin flux for our type of work.
  18. Boreas
    Boreas TDPRI Member
    Port Kent, NY
    Mine looks like a mirror while still hot, but after it cools it dulls. No big deal - the tip will still be tinned the next time you light 'er up! A tip won't last forever - all we are doing here is to help with heat transfer and prolong the life of the tip a little. Best way to preserve a tip is to never use it!
