How to fix tearout
Discussion in 'Tele Home Depot' started by UFO8MyCow, Feb 20, 2013.
  1. UFO8MyCow
    UFO8MyCow NEW MEMBER!
    Blaine MN
    Hello all. I have been reading up on building a guitar for a while now and TDPRI seemed to have the most info of all the forums I found so even though i am building a strat as my first this seemed like the best place to register and ask my first question.
    After getting my shop all setup i finally got around to rough cutting and routing my body but when i was almost done i got some tear out on the top cutaway when the router grabbed and almost ripped the body out of my hands. I really don't want to scrap the whole thing so what are my options for fixing this? Im sure I could use some filler on it but I'm not sure what would be best. I was thinking my other option may be to use the router to take off the top 3/4" or so of material and put in a patch then use my pattern bit to follow the other side. Or is there a better option i haven't thought thought of yet.
  2. Jupiter
    Osaka, Japan
    Are you planning to paint it a solid color?
  3. UFO8MyCow
    Blaine MN
    I hadn't totally decided yet but i was leaning towards white or black.
  4. Glen Smith
    Glen Smith RIP
    If you are going to paint it an opaque color, use Bondo which is used on auto bodies.
  5. Jupiter
    Osaka, Japan
    Yeah, something like bondo. I also have some epoxy-based wood putty that I'm planning to try the next time I have to patch something.
  6. Stuco
    Stuco Poster Extraordinaire
    GA
    I guess a patch would be the 'right' way to repair it, but a small amount of filler is not going to make much of a difference in the finished product. I guess it depends on how much of a perfectionist you are.
  7. philspeed1
    philspeed1 Tele-Meister
    brisbane
    I agree with the others just fill it with a good auto filler if you are painting it no point in anything else. you would be supprised how much filler goes in to some new car bodies.
  8. Shepherd
    Shepherd Friend of Leo's
    Maple Ridge, Canada
    Two part epoxy works great, you can also use it as a grain filler.
  9. guitarbuilder
    You could cut off a portion of the left hand side section and reglue new wood on, and re-do it too. It looks like you have it set to take off too much depth from the mill marks shown.
  10. Ed Miller
    Ed Miller Tele-Meister
    Coldwater, MI
    looks like some of it will go away when you round over the edges.
  11. Ronkirn
    Jacksonville, FL
    take a chunk of wood to the disk sander, generate a handful of wood powder… wet the scar with CA, fill it generously with the wood dust… re wet, add more powder… give it a few to harden.. proceed…
    Ron Kirn
  12. Bronkowitz
    Bronkowitz Tele-Meister
    Chicago
    I'm not sure how much you were trying to remove, but I try to remove no more than 1/16th of an inch. Lately, though, I've switched to using a robosander (flush trim sanding drum) on my drill press to remove most of the waste before routing. For $25, it's a good investment. Tearout never happens anymore, even with highly figured wood.
  13. michael0703
    michael0703 Tele-Meister
    Ponchatoula, La
    I have eyed that robosander a couple times but never pulled the trigger on it. Glad to know it works good. Might have to order one myself
  14. Jimclarke100
    Jimclarke100 Tele-Afflicted
    Horsham, UK
    I have used an epoxy wood filler for just that reason in my latest. So far it seems to be working fine.
  15. Maricopa
    Maricopa Friend of Leo's
    Phx, AZ
    Had that happen not too long ago (on a Tele) and just shortened the horn. If you're not using a ready-made pickguard 99% of people would never notice the slight dimensional change.
  16. Agitator
    Agitator Friend of Leo's
    In transit
    Call it "road worn". :D
  17. whodatpat
    whodatpat Friend of Leo's
    College Park MD
    I use Durhams Putty to address all the bits of character I give a body.;)
    Provided your going for an opaque finish it will be fine. In fact I used it as a poor filler on this project.
  18. koolaide
    koolaide Tele-Holic
    south carolina
    +1
  19. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Albuquerque, USA
    I agree with the Bondo and solid color for this one. Actually PlasticWood would work on your damage and would be a lot easier than the Bondo. Buy the stuff in the tubes. On future builds you might avoid tearout by making shallow passes.
    ......[​IMG]
  20. R. Stratenstein
    Loganville, Ga.
    Spiral upcutting bit, such as the Whiteside, eliminates tearout. If you plan to build more, the cost is justified, IMO.
