How to fix fretboard divot?
Discussion in 'The DIY Tool Shed' started by davemontalvo, May 16, 2021.
  1. davemontalvo
    davemontalvo TDPRI Member
    PA
    I’ve got Squire Strat with a Pau Ferro fretboard with a divot at the 6th fret just under the high E. Is there an easy way to fix this? I’m thinking wood filler, lightly sand it down and then color with a crayon?
    Or do I just leave it alone? It doesn’t affect playing at all. Just cosmetic.
  2. RobRiggs
    RobRiggs Tele-Holic
    Concord, CA
    That’s quite a chunk. I haven’t had good luck with filler on darker wood, rosewood, ebony, pau ferro. You could try some dark sawdust hardened with CA like you’d use to repair re-fret chips.
  3. hepular
    hepular Tele-Afflicted
    abilene, tx
    i'd be inclined to get a tiny wood sample. exacto & file the edges of fingerboard; shape a replacement bit, & glue in & sand and shape.
    Laren, Boreas, dogmeat and 1 other person like this.
  4. dogmeat
    dogmeat Friend of Leo's
    Alaska
    yeah... I would make a clean splice. it would be critical to find the right wood though. maybe contact some guitar builders for scrap chips. anyone do violin repair near you? that might be another source.
    here's Dan...
    Fixing fretboard chips on the Mike Bloomfield Tele | stewmac.com
    on the other hand, he has a thing about tinting epoxy. it wouldn't be a nice looking but a lot easier
    davemontalvo and Boreas like this.
  5. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    Is that clean through to the maple?? Or is Pau Perro another word for plywood?
    Yeah - I would go the punch/plug route - if I were inclined to fix it. Find a small round punch and expand the divot - just like doing a position dot. Find some closely matching veneer and punch a plug. But if you want it to look good, have a pro do it.
  6. davemontalvo
    PA
    I like that sawdust + crazy glue solution. Might give that a try. I have an old rosewood fretboard on a busted acoustic I might be able to use to get some sawdust.
    Boreas likes this.
  7. FenderGyrl
    FenderGyrl Poster Extraordinaire
    Wisconsin
    Buy a cheap Rosewood Acoustic Bridge...sand it so that you have a pile o dust ....
    Build a tape dam along the edge...
    Fill the divot with the Magic Dust...
    Drop some Medium CA into it...
    A little dab will do ...
    Repeat ...
    File .... Sand ...
    Dont use Spray Activator...
    It'll make the repair shinier...
    Use less glue and more dust on each succeeding drop fill
    FG
    88 asat, eallen, davemontalvo and 2 others like this.
  8. guitarbuilder
    If it is an expensive enough neck to warrant extra work, I'd inlay a little piece of wood in there. If it is a MIC neck, I'd pat some dark sawdust in there and drop fill some superglue. Then take an emery board or file and level it.
    davemontalvo and fenderchamp like this.
  9. Freeman Keller
    I fix divots in rosewood and ebony fretboards by powdering a little of the same wood and mixing with a bit of mediumo r thin CA. It might come out darker than the parent wood but it will be better than the hole. One word of warning, however, if you have used any kind of oil or other treatment on your f/b there is a very good chance the repair won't hold. Cleaning with acetone or naphtha might help.
    Ps - fill the divot with the dust, THEN drip the CA onto it. The CA will kick off as soon as it hits the dust and warning, its an exothermic reaction. You might have to do several applications, then sand back and clean up with steel wool.
    eallen, FenderGyrl and Boreas like this.
  10. Boreas
    I would advise doing it in several layers. The larger amount of filler you use at once, the more likelihood of shrinkage and failure down the road.
    I would also try to do it by spreading the mixture around the sides of the crater with a toothpick and not just the bottom. This way, every layer also has less surface to shrink. Eventually, by building up the perimeter, the last application will just be a tiny drop in the center as opposed to a large area across the surface which will be more prone to chipping and wear.
    Cyberi4n and davemontalvo like this.
  11. Collin D Plonker
    Collin D Plonker Tele-Afflicted
    Delaware
    I just repaired damage like that this week. I chiseled it square on the edges and angled on the bottom. I filed the bottom flat. Then I chiseled out a matching piece from scrap and glued it in with ca glue. A little glue and sawdust around the edges, sanded down, and boom. Invisible repair.
    davemontalvo, dogmeat and FenderGyrl like this.
  12. chucker
    chucker Tele-Meister
    New York
    go into the lumberyard and they will have, like colored pencils, i forget the brand, in different wood shades, for filling. what you do is rub the crayon (?) back and forth fast, and it heats the wax compound, and fills up the hole. then afterwards the goop is on the fretboard as well as filling the hole, so you take a piece of cloth and rub it back and forth to clean it up. cost you a few bucks, non shrinking. old carpenter/cabinetmaker trick.
    davemontalvo likes this.
