How to fine tune / reshape existing neck?
Discussion in 'Tele Home Depot' started by yanni, Nov 18, 2017.
  1. yanni
    yanni Tele-Meister
    Germany
    I bought a USACG neck which is very nice but I would like to remove some wood for the shoulders. What tools would you recommend for this ? Would you sand this away or file this aways ? W
    Thanks a lot...
  2. Finck
    Finck Tele-Afflicted
    São Paulo - Brazil
    I'd use sandpaper, by hand... Starting with 80 and going higher...
    I think you have best control this way.
    Torren61 likes this.
  3. Ronkirn
    Jacksonville, FL
    draw lines on the back straight relative to the edges of the neck.. that will give you a reference as you're sanding... and use a spray adhesive to attach the sand paper to a flat sanding block...and use it much like you would a wood plane ... start with 80... then an interim like 150 - 180 .... and finish sand with 240... you really don;lt need to go any higher..
    Now.. if you have not done this before... test your skills on that 69.00 Walmart special you have hiding in the closet somewhere.. FIRST . . . DO NOT "learn" on Grandaddy's '52 Tele...
    Ron Kirn
    Torren61 and John Nicholas like this.
  4. Torren61
    Torren61 Friend of Leo's Silver Supporter
    CA
    I thinned a '77 LP neck with sandpaper exactly as stated above. Lower grit going to higher.
  5. Erwin
    Erwin Tele-Meister
    Affligem Belgium
    Ron,
    My grandfather has a very old and ugly tele like guitar. I think it is one of the first Chinese knockoffs as it says Broadcaster on the headstock. I think they didn't get it right the first time. The electronics are also not right as it doesn't have the neck + bridge setting. Woud that be a good one to practice on ?
  6. Finck
    São Paulo - Brazil
    The block mentioned by Ron Kirn is a must, and some spray adhesive sure facilitates the process (I don't use it, just because the stuff is very expensive where I live, but maintain the sandpaper in place is a pain in the neck).
    I like to put thick EVA between the block and the sandpaper when sanding rounded pieces. I think this helps to reach a softer contour.
