I live in argentina and i cant get one nowhere of that sizeGet a 1/8" aircraft drill bit.
I live in argentina and i cant get one nowhere of that size,
Agree with this. PLUS, the pilot holes don't HAVE to be perfectly perpendicular. Just don't drill any further than you have to. If the screws are perpendicular, you will just have a harder time screwing them in and adjusting. Do as best you can with the aircraft bit.Get a 1/8" aircraft drill bit.
a 12" bit works fine. But there are bit extenders you can buy, I wonder if they are available down your way? Borrow or rent a right angle drill from someone?Hello guys, im on the process of finishing a strat and i need to drill the screw holes for the tremolo claw, i dont have a long drill bit only common ones. Is it possible? Any ideas?![]()
Yes, that's what I used, and good to have on hand.I have a few drill bits with hex shank
I use one of these with a couple of the driver bit extensions
Makes for a pretty long reach
here's a solution... go get the right tool... you can get off ebay for a few $$ which will be about the same as jerry rigging with some of the ideas submitted above is gonna cost.. .... you're drilling wood, so you don't need some exotic metal...i dont have a long drill bit only common ones.
There are, but they suckYes, that's what I used, and good to have on hand.
However, I question if he can't find one type of drill bit how's he going to find another type ?
Are there no "depot" type stores in Argentina
