loopfinding
learning other people's solos is good because it embeds all these little 4-8 note cells subconsciously into your playing. i think it's actually kind of advantageous for originality's sake that you forget large parts of it after moving on to other material.
usually for my own playing, i get licks or melodies that i've heard "somewhere" stuck in my head. so when i'm practicing, i try to actually play them, and then i run them a ton of times and change them to fit/work out as necessary. that way i can just work easily from my own pool in the heat of battle.
also if you work on lines that go over the barline, even if you fail, it makes stuff that has less chords (or just modal) much easier by comparison to be fluid over. if it's a modal or one chord thing, it also spices things up to start making it sound like you're playing over a different but related chord (e.g. playing G7 stuff over a Dmin7), and that just comes sort of automatically by doing that.
