How to build a cabinet that can work for both 8 ohm and 16 ohm amps?
Discussion in 'Shock Brother's DIY Amps' started by etype, Apr 5, 2019.
  1. etype
    etype Tele-Afflicted
    Dallas
    Say I have the following:
    5w head (8 ohm) -- want to use it with an 8" speaker
    15w head (16 ohm) -- want to use it with 2x8" speakers
    So use two 8 ohm speakers in series and install a switch that diverts the wire coming off the (-) of the speaker in use back to the (-) of the jack (instead of to the (+) of the second speaker?
    Does that make sense? I'd have my tech do the work, but is it more complicated than this?
    thegeezer likes this.
  2. D'tar
    D'tar Friend of Leo's
    WNY
    etype likes this.
  3. thegeezer
    thegeezer Tele-Afflicted
    West Michigan
    I have a Marshall 1936 lead cab. It’s 8 ohms at the 2x12 jack and 16 ohms at the 1x12 jack (with the original 16 ohm Celestions). I have an 18 watt head with switchable output. Works great for a variety of applications. My little 5 watt Swart rocks it with both 12s running or the 18 watter either way depending on what’s needed. Do it!
    etype likes this.
  4. Strato50
    Strato50 Tele-Afflicted
    Port Arthur TX
    I have a two 12 cab line that. Follow that wiring diagram above.
    etype likes this.
