How to brighten up my 52 Hotrod Tele?
Discussion in 'Telecaster Discussion Forum' started by tele_jas, Jan 30, 2017.
  1. tele_jas
    tele_jas Tele-Afflicted
    Springfield/Mt.Vernon, MO
    I have a '52 Hotrod Telecaster. The electronics were replaced, before I got it, with 250k pots and the bridge pickup was replaced with a Don Mare El Black Crowe pickup (a slightly hotter "Broadcaster style" pickup). Neck pup is the stock SD mini-bucker.
    I love the tone of this guitar, but I noticed that when I play it live and I switch to any of my other Telecasters, all my other guitars are significantly brighter on my amp (Vox style amps). Actually, the Bright switch is about right.....But I only have a bright switch on one amp, my other (main amp) doesn't have this. So, if I change guitars in the middle of a set or song, I'd have adjust my treble & cut (depending on which way I swap).
    If my 52 HR was just a little darker, I wouldn't mind..But it's considerably darker. Would larger value volume/tone pots make it brighter (500k)? Or what about bypassing the tone pot all together to see if that helps any?
    Any suggestions? I'd like to make it close to my other Tele's so I can just grab it and go.
    I know I'm going to get some people tell me "it's good to have different sounding guitars", but this doesn't work well in a live setting if you break a in the middle of a song and need a quick guitar swap. It doesn't work if you have to run back to the amp and adjust the settings too, if your amp is even accessible - some venue's, it sits off stage.
  2. bender66
    on my bike
    Those came with 375k pots, correct? I have a Firebird with minis & 300k pots It is too dark for my taste too. Those values are fine for the single coil but leave me wanting more for any HB.
    Plenty of diagrams with a 500k pot wired with a resistor so the single coil sees a lower value when selected. I think that's a good option. I have a few saved in my imgur account.
  3. BryMelvin
    BryMelvin Friend of Leo's
    Arivaca AZ
    Just set up with the darker guitar, setting amps settings for it. Then set up your other guitars by using their tone knobs. Memorize those settings after you set it up for future reference.
  4. sonny wolf
    sonny wolf Friend of Leo's
    austin texas
    Maybe installing steel saddles instead of the brass ones would brighten up the acoustic tone and give it more bright twang which will be amplified by the pickups into the amp.I notice Teles I play with steel saddles always give a bit more brightness compared to brass ones.
    KDawg64 likes this.
  5. Vintage Fan
    Vintage Fan Tele-Meister
    Dallas
    Try any or all of these items....Experiment with your pickup heights. Sometimes lowering the pickups brightens things a bit. Try D'Addario steel strings, Install 500k pots or 1meg pots, steel saddles, tusq nut, install Fender 50's Road Worn pickups, remove the neck pickup's cover...Use George L cords with brass plug ins. Use thin picks....all will brighten the sound, so try one at a time so as not to go too bright.
  6. SPUDCASTER
    SPUDCASTER Poster Extraordinaire Gold Supporter
    Grangeville, Idaho
    I have a SC bridge and Firebird neck in a partscaster.
    Started with the 375k volume pot and a no load 250k tone pot.
    Went to a 500k volume pot and a 470k resistor so the SC could see 250k.
    Had it wired so the Firebird(500k), the Firebird/SC(500k) and the SC(250k). Got the schematic from member warparker4.
    The Firebird I'm referring to actually is a Cavalier Phoenix. Cavalier's "Firebird" offering.
    I would try the 375k or 500k before doing anything else. Just economically speaking.
    bender66 likes this.
  7. tele_jas
    That's kind of what I'm thinking.
    With needing to brighten up both pickups here, should I replace both pots with a higher value pot or just the tone, or just the volume?
  8. SPUDCASTER
    Grangeville, Idaho
    I would start with the volume pot. Get a 375k and a 500k pot. A couple of pots won't set you back too much. You'll also need a 470k resistor. Any Radio Shack should have those.
    Do you work on your own stuff or go to someone? I'm out in the middle of nowhere. I do about everything but fretwork.
    As bender66 said, the Hot Rod came with a 375k volume pot originally. At least I'm fairly sure it did.
    I looked up the "El Black Krow"(A5 magnets/7.4k DCR) and it should be fine with the 375k volume pot. You do have a tone knob on the guitar if needed.
    Start with the 375k, if that doesn't fit the bill. Go to the 500k and resistor the bridge pickup.
    You can do a search here for the B(250k), B+N(500k) and N(500k) schematic. Or contact warparker4.
    This is where I would start. Good luck!
  9. bender66
    on my bike
    The tone pot is entirely up to you. Leave it for starters.
    tele_jas likes this.
  10. jvin248
    jvin248 Doctor of Teleocity
    Lions & Tigers oh Mi !
    500k volume pot. You could try a 1Meg volume pot for more brightness. Use an ohm meter to measure the actual pot values (they can be +/- 10% from target so if you have several find the highest kohm one for this)
    0.047uF cap in series with the dark pickup or in series at the switch if both pickups are dark.
    If the tone cap is 0.047 then put in a 0.033 or 0.023uF tone cap and use the 0.047 as the series cap.
    SD forums have a thread about fixing muddy pickups with the series cap. Elsewhere are scattered notes about Roy Buchanan's Nancy Tele bridge pickup had a deep break in the coil in such a lucky spot that the coil still worked but as if it had a series capacitor to give the brighter tones he got out of it.
    Later, plug this guitar and your backup guitar into your amp and change the pickup heights to better match volume and breakup.
  11. Ripradiant
    Ripradiant Tele-Afflicted
    Alberta Canada
    I don't think a mod is the right way to go.... I would call the doctor: sounds like your tele is ill.
  12. absurdocaster
    absurdocaster Tele-Meister
    Calgary, Canada
    I have a stock 52 hotrod and haven't noticed the same issue (although I'm using fender amps). Have you considered return it to stock? I'm not sure what the exact stock set up is but I know that Fender set it up so the pickups worked well together and remained balanced. It is certainly a hotter set up than a standard 52 tele.
  13. SPUDCASTER
    Grangeville, Idaho
    Not sure what amps he's using. Someone changed the original wiring scheme, that's the problem.
    I/we have suggested that he return it to the 375k volume pot(original spec) and if that isn't bright enough go to a 500k.
  14. absurdocaster
    Calgary, Canada
    Thanks I missed the details in the earlier posts. A quick draw post problem on my end.
  15. SPUDCASTER
    Grangeville, Idaho
    Been there, done that. It's all good.
  16. tele_jas
    Dr. Z Stingray and a Morgan DAG15...Both pretty bright, AC15/30 voiced amps.
  17. KB11
    KB11 TDPRI Member
    Royal Oak, Mi.
    Seems simple enough to change out the bridge pickup for a more normal sounding one.
  18. Corgitodd
    Corgitodd Tele-Meister
    Cleveland
    1 meg pot like on 70s teles. You'll be so bright folks will call you Sunny.
  19. tele_jas
    When the amp is dialed in for this guitar, the pickups are a GREAT match for each other...So I don't want to change that.
    I just need to brighten up the whole guitar, not just the bridge, so I'm going to try 500k pots.
  20. mckeeiain
    mckeeiain Tele-Meister
    Moncton NB
    I will always own a tele with the standard pickup config SS; HOWEVER the 52 Hot Rod is one of my dream guitars. I love the sound of that SD mini-bucker and have heard few guitars that I like more.
