How to balance Plexi clone while working on it?
Discussion in 'Shock Brother's DIY Amps' started by itsGiusto, Jul 9, 2020.
Tags:
  1. itsGiusto
    itsGiusto Tele-Meister
    Massachusetts
    I'm still debugging what I think is parasitic oscillation causing weird fizzy swirly distortion in my Ceriatone Plexi clone (without much luck). I need to have the board in the chassis exposed while working on it so I can do things like take voltages, listen to the audio at various points, and use an oscilloscope to probe the signal.
    I can rest it upside down so that it's balanced on the transformers and EL34s, but the EL34s get so hot that I'm not it's safe to rest it on most surfaces - things could burn or melt.
    How do people manage this? Is there anything safe I can rest the amp on upside down?
  2. Wayne Alexander
    Wayne Alexander Friend of Leo's Silver Supporter
    Los Angeles, CA, USA
  3. Peegoo
    Peegoo Friend of Leo's
    Planet Peegoo
    In a pinch you can empty a small deep dresser drawer, place it on the workbench, and set the hangy-downy bits of the amp into the drawer with the amplificator's chassis supported on each end by the drawer sides.
    Necessity is the mother of amplification, I always say.
  4. Ten Over
    Ten Over Tele-Holic
    Central California
    I just take some of those books my girlfriend bought and put them under the transformers so that the power tubes are dangling in free air. If I'm going to do anything that is very involved, I put the amp in a cradle that I made for just a few bucks.
  5. itsGiusto
    Massachusetts
    Cool. I didn't do this exactly because I don't have the right size drawer. But I instead propped it up with two small drawers, one on either end.
    Peegoo likes this.
  6. Peegoo
    Planet Peegoo
    iMuy excelente!
  7. jtcnj
    jtcnj Tele-Holic
    Brick, N.J. USA
    2 or 4 short cuts of 2x4 work well for me.
    Paul G. and fenderchamp like this.
  8. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Yep...I use wood blocks of various thicknesses on each end of the chassis to support it high enough that the tubes don't touch. For smaller amp chassis I have some hard foam blocks that I use to support it while working on it.
  9. tele_savales
    tele_savales Tele-Holic
    Brooklyn, Joey!
    One end on the coffee table and the other on your 1x12 combo amp
  10. rangercaster
    Knoxville TN for now
    Peegoo is usually correct 99. 999%
    Of the time ...
    But when he's wrong ...
    It could be fatal ....
    Fair warning ...
    Peegoo likes this.
  11. Peegoo
    Planet Peegoo
    rangercaster likes this.
