How to age aluminum parts to look ANCIENT.
Discussion in 'Tele Home Depot' started by Newbcaster, Jan 30, 2019.
  1. Newbcaster
    Newbcaster Tele-Holic
    Gilbert
    You know, to look dark, dank, like someone unearthed it from a viking tomb in 630 AD.
  2. ponce
    ponce Tele-Holic
    Croatia
  3. Lonn
    Lonn Friend of Leo's
    Indiana
    Muriatic acid FUMES. DO NOT let the acid touch the metal, just the fumes.
  4. Sparky2
    Sparky2 Friend of Leo's
    Harvest, Alabama
    There's a bathroom cleaning product called The Works.
    I don't know what's in it, but it
    a. Does a great job of cleaning porcelain toilets and sinks
    and
    b. It does a wicked job of staining and discoloring silverware and stainless steel sinks
    It would likely do the job on your aluminum bits and parts.
    Newbcaster likes this.
  5. ponce
    ponce Tele-Holic
    Croatia
    You can controll the blackness with the different application time and preparation level (sanding).
  6. jimgchord
    jimgchord Tele-Afflicted
    victor,ny
    That would consume the aluminum and release toxic gas
  7. Sparky2
    Harvest, Alabama
    I envisioned some experimental applications of a short duration, with nearly immediate rinsing-off, and burnishing with sandpaper as necessary.
    Either that, or he could leave his bits and parts in a Viking tomb for 1,389 years.
  8. jimgchord
    victor,ny
    That probably would do it. Maybe just wipe on a thin layer and let it "work"
  9. Newbcaster
    Gilbert
    what happens when acid touches metal in this case?
  10. trev333
    Coolum Beach,Australia
    Aluminium corrodes pretty fast and turns to oxide... keep the acid/alkali weak....
    I doubt if there is any ancient Ali dug out of the ground...especially if there's any salt around... ;)
    notmyusualuserid likes this.
  11. tanplastic
    tanplastic TDPRI Member
    Aluminum looks pretty bad when it oxidizes, turning into a white powder.
  12. tanplastic
    Not sure if that's what you want.
  13. tanplastic
  14. tanplastic
    Apparently this was important enough for me to post 3x.
    Mike9 and Rev Rhythm like this.
  15. blowtorch
    Wisco
    Just how ancient?
    Aluminum was used at least 7,000 years ago and our modern discovery of this valuable metal is nothing but a re-invention based on knowledge our ancestors already possessed.
    While excavating in Iraq, archaeologists discovered pottery produced around 5,300 B.C. These artifacts were made of clay that contained aluminum.
    http://www.ancientpages.com/2017/07...ears-ago-long-metals-official-invention-1825/
  16. aerhed
    aerhed Friend of Leo's
    Boulder, WY
    Aluminum does not rot gracefully.
    tanplastic and notmyusualuserid like this.
  17. Lonn
    Indiana
    what happens when acid touches metal in this case?"
    The metal melts, especially the old zinc trem blocks. Found that out the hard way.
  18. tele_savales
    tele_savales Tele-Meister
    Brooklyn, Joey!
    I tried to use ferric chloride on an aluminum control plate from Rock Rabbit and it bubbled the chrome right off in less than 3 seconds. Not ideal. But then I polished it back a bit and it looks reasonable.
  19. strat a various
    Aluminum looks crappy as it oxidizes. It gets bumpy and riddled with white "warts". If you want it dark, find a translucent tinted polyurethane coating you can apply in coats until you get the effect you want.
  20. notmyusualuserid
    notmyusualuserid Friend of Leo's
    In the South
    Leave it outside for a month or two. Sprinkle some salt on it occasionally.
