How Tight Truss Rod Should Be
Discussion in 'Tele-Technical' started by RoCkstAr256, Aug 6, 2019.
  1. beagle
    beagle Friend of Leo's
    Yorkshire
    All I can tell from that is the allen socket is ok. Trying to turn a truss rod with the tiny allen key that is supplied (sometimes) with a guitar isn't the easiest thing to do. Something like this make it much easier.
    RoCkstAr256 likes this.
  2. RoCkstAr256
    RoCkstAr256 Friend of Leo's
    Poland
    Not having this tool, ill buy it soon in a Store
  3. tele_savales
    tele_savales Tele-Holic
    Brooklyn, Joey!
    STewmac has em for like 90 bucks.
  4. RoCkstAr256
    Poland
    Quite far away from my place ;)
  5. tele_savales
    Brooklyn, Joey!
    I was making a joke about their high prices for basic tools, but yes the shipping would be prohibitively expensive.
  6. dan1952
    dan1952 Friend of Leo's
    Anderson, IN
    From the photos you've posted , the truss rod nut looks slightly rounded off/stripped.
  7. RoCkstAr256
    Poland
    That What i was thinking about :)
  8. Chunkocaster
    In space with Ziggy
    With no string tension on the neck I sometimes bend the neck on my knee to help it along if the truss rod seems too tight. If there is too much resistance stop. F style necks are pretty tough and you wont break it by forcing pressure over your knee, truss rods not so much.
  9. beagle
    Yorkshire
    You can clearly see all the internal angles are ok in this picture.
    dan1952 and RoCkstAr256 like this.
  10. RoCkstAr256
    Poland
    So everything is alright i guess :)
  11. Chunkocaster
    In space with Ziggy
    Not sure if its already been said but work in quarter turns and let it rest if it's still tight and not producing results immediately.
    Bluesbob and stevemc like this.
  12. beagle
    Yorkshire
    Or even 1/8th turns. A little goes a long way.
  13. Chunkocaster
    In space with Ziggy
    I like to adjust mine over a couple days. Get it right on first try and check again the next day when its been played a bit and had string tension back on it for a while.
    I'm mostly doing tr adjustments on newly fitted necks though as my necks are all pretty stable once set up and played in.
    Muku, RoCkstAr256 and beagle like this.
  14. beagle
    Yorkshire
    I adjust mine with the strings on and more or less tuned, but I rarely ever have to adjust them twice.
    macatt and Chunkocaster like this.
  15. Chunkocaster
    In space with Ziggy
    Mine are nearly all adjusted at the heel. A real pita initially but luckily they are stable once set up so rarely need adjusting.
    beagle likes this.
  16. beagle
    Yorkshire
    Yeah, I can't adjust those with the strings tuned, but I haven't taken a neck off for 13 years, most of the necks I've adjusted since then have been Squiers. Some have been quite tight, some completely loose. It all depends how much correction the individual neck needs.
    RoCkstAr256 and Chunkocaster like this.
  17. RoyBGood
    RoyBGood Doctor of Teleocity
    Northamptonshire, UK
    Tuco likes it very tight:
    LutherBurger and Chunkocaster like this.
  18. RoCkstAr256
    Poland
    Ok
    Okay will do mate
    Chunkocaster likes this.
  19. dan1952
    Anderson, IN
  20. macatt
    macatt Tele-Holic
    silverdale wa
    I bend it over my knee after adjusting the rod.
    That way it does respond immediately; no waiting at all.
    S Mac
    beagle likes this.
