How Tight Truss Rod Should Be
Discussion in 'Tele-Technical' started by RoCkstAr256, Aug 6, 2019.
  1. RoCkstAr256
    RoCkstAr256 Friend of Leo's
    Poland
    I have two mexi Teles, the newer one has really right truss rod, i only have tried to turn it slighlty, it took me like twice as much force to do it. Truss rod tightness can be different ?
  2. schmee
    They should be in the center of the neck, not right or left.... :lol:
  3. Bendyha
    Bendyha Friend of Leo's Silver Supporter
    Northern Germany
    Quite right!
  4. RoCkstAr256
    Poland
    R is near T, damn keyboard. I meant tight
  5. Matthias
    Matthias Friend of Leo's Gold Supporter
    Some of mine need a bit of force (not excessive). It depends how much bow they’re offsetting. A neck that’s naturally straight can do so with a fairly loose truss rod. I would guess to looser one is just a naturally straighter neck.
    telemnemonics, simond and RoCkstAr256 like this.
  6. EsquireBoy
    EsquireBoy Tele-Afflicted
    Paris, France
    « Hard to turn » does not equal « tight » in this case.
    If your neck relief is right, your truss rod cannot be too tight (unless it is already maxed out, in which case it is not normal in a newer guitar).
    But it may very well be that the screw is not lubricated enough to enable you to turn it easily enough. In this case wd40 is your friend!
    Also loosening your strings helps a lot and avoid to put too much stress on the screw.
    RoCkstAr256 likes this.
  7. RoCkstAr256
    Poland
    It is quite hard to turn but not Impossible, i guess every guitar is different ?
  8. tele_savales
    tele_savales Tele-Holic
    Brooklyn, Joey!
    I can already hear the collective groaning of the entire forum membership about using wd-40 for this purpose.
    steadyriot, Muku, TeleTucson and 6 others like this.
  9. EsquireBoy
    Paris, France
    I do not see how it could do some damage if used once and little, but I am more than ready to stand corrected.
  10. EsquireBoy
    Paris, France
    Right! A few years ago I had a luthier of good reputation build me a custom guitar and the truss rod was hard to adjust, so much that I did not dare to apply more strength to make it turn.
    His advice was: loosen the strings and put a drop of wd40 onto the screw. It worked perfectly and I’ve never had any trouble adjusting it since then.
    Chunkocaster and RoCkstAr256 like this.
  11. RoCkstAr256
    Poland
    Good to hear, i dont mind it being harder to push. It felt weird to my other guitar
    EsquireBoy likes this.
  12. Deeve
    Deeve Poster Extraordinaire Silver Supporter
    Ballard
    When in doubt - twist in the OTHER direction first - to see how hard it is to turn.
    I don't know of ANYbody telling a story involving a "tight" trussrod adjustment that got better w/ application of More Force.
    Peace - Deeve
  13. LutherBurger
    LutherBurger Friend of Leo's
    NYC
    I've done the same with 3-in-1 oil on a Q-tip, with the same result.
    howardlo, EsquireBoy and RoCkstAr256 like this.
  14. RoCkstAr256
    Poland
    It was same in both directions
  15. tele_savales
    Brooklyn, Joey!
    Hmmm... Traditional wisdom would be that eventually, it would loosen up if you keep turning it to the left. Which if it's that stuck, I would do very carefully, then lube the threads with a lubricant and re-tighten it back to where your desired relief (up-bow) is.
    RoCkstAr256 and Deeve like this.
  16. Dacious
    Dacious Poster Extraordinaire
    Godzone
    You are loosening your strings? Never turn a truss rod either way with strings at pitch!
  17. dreamingtele
    dreamingtele Friend of Leo's
    Melbourne, Australia
    I had a strat, tight truss rod, hard to turn, I used force, truss rod broken.. I got lucky it got covered by the store I bought it from and I just returned it and added cash for the next higher model..
    so now, I turn it lose first to check if its okay then tighten it a few turns at a time to see if it's maxxed out or I still have room for adjustment..
    although I had a Cort acoustic, it was really good sounding, but to get the neck straight, I had to turn the truss rod very tightly, almost maxxed, because Im using 12-54's at that time and the thin neck might be having a hard time with the heavier gauge tension on it..
  18. RoCkstAr256
    Poland
    I captured some photos of front of truss rod, this may help. Couldnt get better quality
  19. beagle
    beagle Friend of Leo's
    Yorkshire
    How tight the nut is to turn on the rod would depend on the amount of force it is exerting on the neck in order to counteract the natural tendency to bow under tension from the strings. The tighter it needs to be, the harder it gets to turn.
  20. RoCkstAr256
    Poland
    From the photos i have posted, especially 4th photo. Does it look ok from top ?
