surfsup1955
My first thought too… but from experience, these strings tend to break easier than ‘regular’ strings at standard tuning.If you go with the half-step up path then you may want to consider Silk & Steel strings.
Roscoe:Hey, all. Hope this finds you well.
So as I begin rehearsing for some down-a-now-visible-road shows I notice that I can sing quite a few of my songs "better" a half-step up from the keys in which I originally wrote them.
So snapped neck/lifted bridge-wise, how risky is it to tune your acoustics a half-step higher?
I'd just use a capo at the first fret except for
A) I'm so old that I'm ossified into where I expect the inlayed markers to be. I don't watch the fretboard too much, but when I do, being a fret up from where I expect to be instantly disorients me. And I doubt I can train myself to not look at the fretboard at all while performing. Many of these songs I've played for 10 years+ in a given key, and I generally don't play in flat or sharp keys. Capoing a G to A, sure. But a G to an Ab? My fingers and voice can do that. My eyes can't.
B) A few songs have a drop D on the low E string--meaning I capo at the 2nd fret but leave the low E uncapoed, so playing in "D" shapes = E, with that low, open E ringing. If I'm playing a half-step up, I'd need a second capo at the first fret, making an F note, to mimic leaving the regularly-tuned low E string open. I'd rather not trust two capos at once, especially since you always gotta fiddle a bit to re-tune capoed/uncapoed guitars.
My acoustics are a late-90's Sigma D-18 that seems rock-solid, and I-dunno-the-era 2nd-hand Martin D-15M that I had to fix when I got it (cracked body sides and cracks behind bridge). I use medium (.013-.056) strings.
Thanks for your advice.
Same here, at 74.Umm, I'm 65 and using a capo wherever I need it is not a problem.
Ernie Ball Rock and Blues acoustic strings. 10-52 with a plain G. I use them on my Gibson L-00, don’t lose much volume, and I could probably tune up a full step and have less tension than 13s.Hey, all. Hope this finds you well.
Also, I’m confused as to why you’d need a second capo.
Tune to drop D, or any tuning for that matter, add a capo at the fret of choice and the interval stays the same.
You will get raised action immediately and a bellied top later. The Sigma would probably fare better than a presumably lighter-braced Martin. And the string tension would overall be unpleasant for playing.So snapped neck/lifted bridge-wise, how risky is it to tune your acoustics a half-step higher?
What about one of these? I down tune a whole step abd then use a regular capo and just cover 5 strings for drop D but kyser make a special short capo. https://kysermusical.com/products/k...ustic-guitar-capo?_pos=2&_sid=b8df5d794&_ss=rHey, all. Hope this finds you well.
