Nicko_Lps
Greetings everyone,
Im wondering, how exactly did they manage to make a power tube section work with 2x6L6 or 4x6L6 or 2x6L6+2xEL34 or 4x6L6+2xEL34.
I can see from their schematic that they use relays to switch on/off the cathode connection to ground, yet my question is...
How exactly the output transformer impedance is working in this case? By disconnecting the cathodes on 2 out of 4 tubes for example, just because the plate and screen grid remains connected to the output transformer, the impedance remains unaffected ?
Does that mean(for example) that you can add a switch to a 4 power tube marshall or fender and simply disconnect the 2 tubes cathode and operate in a 50 watt mode?
In their case cant post any schematic or name for the obvious reasons, im pretty sure everyone can get a roadking2 schematic from the internet and take a look on what im trying to understand!
I do see in their schematic 1 tap in their output transformer but their schematics are mostly for relevance, Also it seems that EL34's have the outer(higher impedance) tap that adds more confusion to the subject.
