How loud is 10 watts and 6 watts
Discussion in 'Amp Central Station' started by Tazz3, Oct 6, 2015.
  1. Tazz3
    Tazz3 Friend of Leo's
    East islip ny
    Sorry for this question I have a 10 watt tube amp on pre order
    Now Iam thinking it might be to loud lol how loud is it??
    It does have the one watt option will that make it not as loud,
    I was also looking at the VHT 6 watt tube amp it also has 3 watt option
    This amp will be for home use, people Complain my 8 watt front man is loud lol
  2. Jupiter
    Osaka, Japan
    They all got at least one knob that makes 'em quieter. :D
    The difference in perceived loudness between 6 and 10 watts is so small that it can easily be made irrelevant by differences in the circuits, speaker efficiency, etc.
    Even 3 watts is going to be too loud in some living situations if it's cranked...
  3. MilwMark
    near Arnold's
    3 watts is really loud for cranked home use. 10 watts is even louder. But that is also misleading. Speaker "efficiency" has more to do with volume than watts. A 6 db increase in speaker efficiency will make the same wattage amp seem twice as loud if I recall correctly.
  4. PumpJockey
    PumpJockey Friend of Leo's Ad Free Member
    New Joisey
    Don't forget the speaker part of the equation. A 6w with an efficient speaker will be as loud as a 10w with an inefficient speaker. The perceived difference is nil anyway. I have a 6w Champ style amp with an old, inefficient Magnatone speaker in it and it is too loud for the house when cranked.
    You will probably end up turning it down and using a pedal for breakup no matter which one you get, so get the one that sounds the best to you. 10w is a nice starting point. You can even do small gigs with it, especially if you get an extension cab.
  5. soulman969
    Englewood, CO
    No appreciable difference between 10w and 6w if both are running the same or an equivalent speaker. Is it the volume people are complaining about or he fact that you're playing with a lot of distortion? Loud and clean might be more tolerable than loud and distorted.
    Since it has a 1 watt option you can operate off of that. It may not sound as good but it will be quieter. IMHO play the amp at it's full 10w but keep the master volume down. I have 5w, 15w, 40w, and 60w amps that I play all the time and I have neighbors on all sides of me who don't complain.
  6. VWAmTele
    VWAmTele Friend of Leo's
    FL
    A wide-open 5 watt amp can peel the paint off your walls. Everyone has their own definition of 'home amp', but you'd have to have a pretty big home to play a 5 watt amp without being heard in every room.
  7. FenderBender10
    FenderBender10 Tele-Holic
    Pacific Northwest
    It really depends on volume settings. My 3/5 watt amp gets LOUD when cranked and easily shakes the pictures on my walls and next up I can play my ac15 2x12 or 20 watt Princeton at very quiet levels and they sound great. My Vox has a master volume so I can get some OD at low volumes, and my Princeton sounds great on 2(very quiet) but really opens up nice around 6(very loud).
    The amp you have on hold is the Laney Cub correct? That has power scaling down to 1 watt, like you said, so you can really cook those tubes for some nice OD at very low volumes.
  8. Speedy454
    Speedy454 Tele-Holic
    Highland, IL
    For the technical answer, as others have said, loudness is mostly a result of speaker efficiency.
    Take a modern Eminence 12" driver:
    They are typically rated about 102db at 1 watt at 1 meter.
    102db is pretty darn loud.
    To increase loudness by 3db, you must double the power.
    A 3db increase is generally accepted as a very small increase in sound level.
    So 2 watts with this driver is 105db
    4 watts, same driver, 108db
    8 watts, 111db
    16 watts 115db
    32 watts 118db
    64 watts 121 db. 120db is generally accepted as the threshold of pain.
    But if you start with an inefficient driver, say 88db at 1 watt at 1 meter, it is a whole new ballgame. You would need 32 watts to get to the same sound pressure level (SPL) the efficient driver was at with only 1 watt.
    Just for another reference, at 85db or above in a workplace, OSHA requires hearing protection.
  9. kelnet
    kelnet Telefied Ad Free Member
    Port Moody, BC
    I have a 30 watt Peavey Delta Blues that I use at home. It's never too loud because I don't turn it up.
  10. Speedy454
    Highland, IL
    An option to reduce the loudness is a good power soak.
    They go by different names, but it is basically a high power rated variable resistor that allows the player to crank the amp to its sweet spot, and absorbs most of the power silently, passing only some of the power to the speaker.
    For these low power amps, I have heard of people stringing small outdoor light bulbs (10w variety) in series as a power soak. Light up the bulbs and keep the speakers relatively quiet. But since the resistance of the bulb changes with the amount of power through it, the bulbs are a little unpredictable. Fun though.
  11. pluckin'canuck
    pluckin'canuck TDPRI Member
    canada
    I have the vht special 6. I have neighbour's who live below me. They have never complained but I can keep it decently low on the 3 watt setting. Also the special 6 is a really sweet little amp.
  12. LeftFinger
    LeftFinger Friend of Leo's
    Saskatchewan
    I always thought 15w was a starter amp:oops:
  13. Frodebro
    Seattle
    Most of the $100 entry-level amps are in the 15 watt range, sure, but power output has absolutely no bearing on the quality of the amp or its intended use.
    Another thing to remember is that the rated output of the amp is not a constant-a 100 watt amp with the volume turned way down may only be putting a couple of watts to the speakers-it isn't 100 watts across the dial.
  14. Tazz3
    East islip ny
    Thanks guys, so I guess I have to keep it on 1 watt or 3 watts lol
    But speaker has more to do with it the. Any thing I think I under stand lol
  15. Lunchie
    Lunchie Poster Extraordinaire
    Downstate Illinois
    Yes and no...
    Your not going to be running your amp wide open at 4am I would assume. So the real trick is to find an amp that sounds good enough to make you want to play at the lower respectable volumes.
    I no longer have it but even the 50 watt 5153 sounded great at middle of the night whisper quiet volumes. It sounded even better at the wide open middle of the day volumes. :cool:
    So yes even at 1 watt you can piss off the neighbors, if you crank it to 10. On 2 you may annoy the dog who's trying to sleep on the couch next to you but the cops won't be knocking down your front door.
  16. homesick345
    Beirut, Lebanon
    The 1 watt option will sound half as loud as 10 watts
    This might well wake the neighbours if turned up (whether 1 or 10 watts)
  17. 24 track
    24 track Doctor of Teleocity
    kamloops bc
    I have 2 Beltone amps one is 8 watts the other is 15, both use EL84's the 8 watt is enough to drive my 4X12 cab nicely. and I have gigged with it in small venues, without the 4X12 cab, it has an 8" 8 OHM spkr and sounds great.
  18. Doctorx33
    Doctorx33 Tele-Afflicted
    Atlanta
    It's easy to build a simple attenuator for these small wattage amps, that's what I do.
  19. LKB3rd
    LKB3rd Friend of Leo's
    CT
    Somewhere i read that 6 watts tube amp is around as loud as a trumpet. Seems about right to me. A trumpet playing in the house is pretty loud.
  20. Marshall_Stack
    Marshall_Stack Friend of Leo's
    Portland, Maine
    Ha! - I first read this as "It's never too loud because I don't turn it on."
