How long must water based dye dry before applying tru-oil?
Discussion in 'Finely Finished' started by koolimy, Aug 12, 2019.
  1. koolimy
    koolimy TDPRI Member
    Hello, I have been making a telecaster from thefretwire.com
    I have already dyed the guitar using angelus leather dyes - which I believe are water/alcohol based aniline dyes.
    I have waited about 16 hours after dying my body, but I found that when I wipe the body with tru-oil, some of the dye bleeds onto the rag.
    How long must I wait to apply tru-oil? Thanks for any replies.
    PingGuo likes this.
  2. Chunkocaster
    In space with Ziggy
    I would give it at least a few days in warm weather.
    I have applied tru oil over amber tinted necks a day later but bodies tend to soak up more water than a hard maple neck would.
    rangercaster, koolimy and nojazzhere like this.
  3. koolimy
    Okay, thanks! It sucks that I already applied a coat to the back, but maybe have to just live and learn. Hopefully one coat of tru oil won't cause other problems down the road.
  4. Chunkocaster
    In space with Ziggy
    It should be ok, I imagine the finish will just end up looking cloudy if there is still too much moisture in the wood. I would leave the rest for a few days to be safe.
  5. bender66
    on my bike
    Before you proceed I'd try that on scrap.
    I'd worry that the TO is gonna pick up your dye regardless.
    Or maybe a thin coat of shellac?
    nojazzhere likes this.
  6. Chunkocaster
    In space with Ziggy
    The dye mixing with the tru oil is not that much of a problem. I add undiluted colortone liquid stain directly to tru oil to tint necks and it works fine. The moisture from the added water is what I would be concerned about along with possible streaky or blotchy looking stain job if the tru oil picks up too much of the dye.
    koolimy and bender66 like this.
  7. koolimy
    Thanks for the comments. What are the potential problems if the moisture can't escape due to the coat of tru-oil? Could there be mold, etc.?
  8. PingGuo
    PingGuo Tele-Afflicted Silver Supporter
    North FL
    Wait!
    Isn't anybody going to say it....?
    That guitar looks flipping GREAT!
    that's going to looks so so so good once you get the TO on there.
    Anyhow, like others said, you could seal it with shellac if you find the TO is picking up too much of the dye even after a few days. But you'll probably be fine in a few days time.
  9. koolimy
    Thanks! I appreciate the comment. I actually just followed this video, and it was surprisingly easy to do!
    PingGuo likes this.
  10. draggindakota
    draggindakota Tele-Meister
    Lehigh Acres, Florida
    I just refinished a neck with Angelus dyes and tru-oil. I waited 24 hours for the dye to dry before starting with the tru-oil and the first 2 coats still picked up a small amount of color. It seemed to me like it was just dried dye that hasn't absorbed but it didn't seem to affect the final product.
    koolimy and SecretSquirrel like this.
  11. koolimy
    My biggest worry is the tru oil picking up the darker colors and bleeding them into the lighter colors. I'm guessing there was no problem with the dyes getting smudged onto other parts of the neck?
  12. Vizcaster
    Glen Head, NY
    The issue might not be "drying" but instead the dye you used is probably going to re-dissolve in the solvent in your wipe-on varnish no matter how long you wait (don't be offended by my calling TruOil a varnish, the point is it is a mixture of oil and other things particularly solvent). Any wiping finish runs this risk. You sort of have to apply the first coat carefully, let it dry, then hope the dye is locked in so it won't bleed further.
  13. Silverface
    Lawndale CA
    You can pick up a moisture meter at Harbor Freight or on Amazon for about $15-25. I always measure moisture content prior to coating or staining (Tru Oil is more a Danish Oil stain than a finish - there's VERY little film build).
    The acceptable limit for moisture content is 11%, although some of us use 8%since you can't test every square inch.
    If it's over 11% - it's not dry. Simple as that.
  14. draggindakota
    None at all. It did lighten the color slightly overall. You can see pictures here --> https://www.tdpri.com/threads/douglas-gravity-rebuild.965042/#post-9252637
  15. koolimy
    Hi all, thanks for the replies. I waited for a few days before applying the next coats, while trying to wipe as much of the dye off as possible with a dry cloth. The first coat still picked up a lot of dye, but subsequent coats picked up nothing. I'm guessing it's part of using dyes. I tried as best to wipe downward so that the darker colors wouldn't blend, and it seemed to work out okay.
    Nonetheless, I'm finding myself having a different problem. I'm finding that both my neck and body are feeling a little sticky. Is it normal for tru-oil to feel a little sticky, even after 2 days? The neck feels stickier than the body, probably because the body is much more porous.
  16. Silverface
    Lawndale CA
    It's a random issue - happens sometimes and not in others. If it doesn't dry fully after 4-5 days there may be a compatibility problem between the Tru Oil and whatever was used to let down the stain (or its base if it was used straight.). Was ANY other material sed - sealer, filler etc?
  17. koolimy
    No, nothing other than the dyes were used on the body. The neck had nothing else but sanding. The neck is especially puzzling because I was putting on really thin coats (put it on w/ cloth, and wipe away almost everything) and usually waited at least 16+ hours before applying the next coat. I have around 8-10 coats on the neck, and about 2-3 coats on the body.
    I'm wondering if I'm being a bit paranoid. My only reference is a MIM strat which has a silky smooth, glass like neck. Is it normal to have a little bit of resistance when moving your hand up and down the neck? I also feel like the tru-oil neck gets stickier the more I sweat, which doesn't happen w/ the strat.
