Short on cash
The last payment.
Kind of off topic but an interesting story about planned obsolescence. Did you know that the technology existed 100 years ago to make light bulbs last a lifetime? The light bulb manufacturers got together in 1925 to set the limit at 1,000 hours, which they strictly enforced with financial penalties to any manufacturer that made better bulbs. The average life span for a consumer light bulb prior to 1925 was 2,500 hours!
But given the thread's title "How long is a Tonemaster amp designed to last? FACTS ONLY.",perhaps it's time for our admins to consider closing this one down. Just my opinion, not a fact.
That’s not necessarily true. For something like a spacecraft, or something designed to work on the Martian surface which is equivalent to 22 mikes above the Earth’s surface (roughly halfway to space), the main issue with chips is radiation (cosmic rays, solar wind, etc.), so the chips would typically be designed for that environment (”rad-hard”), or heavily shielded. Either way, the the performance per dollar is drastically less than the equivalent hardware on Earth.You can rest assured that the chips, transistors, resistors and caps used on earth for ANYTHING are nowhere near the quality of the ones used on the Mars Rover.
All general public consumer products are designed to fail. Some, built in "other countries" have higher failure rate and obvious low quality to begin with.That’s not necessarily true. For something like a spacecraft, or something designed to work on the Martian surface which is equivalent to 22 mikes above the Earth’s surface (roughly halfway to space), the main issue with chips is radiation (cosmic rays, solar wind, etc.), so the chips would typically be designed for that environment (”rad-hard”), or heavily shielded. Either way, the the performance per dollar is drastically less than the equivalent hardware on Earth.
Aerospace systems are designed to a price point too, but depending on the part, the consequences of failure can be death or serious injury, so we commonly look at parts whose failure rates are measured in tens to hundreds of thousands of flight hours. As fas as I know, your typical guitar amp isn’t standing between the guitarist and certain death, but then again I don’t know where you gig![]()
The famous lightbulb at the Livermore Fire Station has been reportedly burning for over 120 years.Kind of off topic but an interesting story about planned obsolescence. Did you know that the technology existed 100 years ago to make light bulbs last a lifetime? The light bulb manufacturers got together in 1925 to set the limit at 1,000 hours, which they strictly enforced with financial penalties to any manufacturer that made better bulbs. The average life span for a consumer light bulb prior to 1925 was 2,500 hours!
The "people behind the curtain" have great plans concerning "us". Rarely are they good plans.All general public consumer products are designed to fail. Some, built in "other countries" have higher failure rate and obvious low quality to begin with.
