How long can I leave a set-neck Tele unstrung.
Discussion in 'Tele-Technical' started by Williams, Jul 20, 2013.
  1. Williams
    Williams Tele-Meister
    Pasadena
    I need my set-neck Thinline Tele refretted, but I have to save up for it, so I've taken the strings off and left it in it's case. The question is how long can I leave it that way without causing back bow? I live in So Cal so the temperature here is pretty mild.
  2. KenH
    KenH Tele-Holic
    Pennsylvania
    I loosen the truss rod if the neck is going to be unstrung for any duration.
  3. Pete W
    Pete W Tele-Meister
    Never leave strings off the neck or loosen the truss rod unless required for a setup unless you want to risk a twisted neck.
    I see wrecked necks all the time because of crazy suggestions to remove strings or slacken them off for storage.
  4. sjruvolo
    sjruvolo Tele-Meister
    New York
    +1 I agree no need too. The neck is designed to have tension on it. Why would you keep it in an other condition.
  5. Rob DiStefano
    Rob DiStefano Doctor of Teleocity Vendor Member
    NJ via TX
    it just doesn't matter.
  6. brookdalebill
    Austin, Tx
    What Rob said.
  7. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    That implies that there is some kind of engineering decision by the builder, and that's just not the case. Sometimes they use quartersawn wood, sometimes they don't, and that's about as far as the engineering goes.
    Having the neck under tension won't cause it to twist. Leaving it without tension won't cause it to twist either.
    Take the strings off and adjust the truss rod so that the neck is as straight as is possible (this might mean fully loose, it might not). Wood will tend to take a set in a certain position, and if there's too much bow or a back bow, it can take some extra work to get it straight when the time comes to refret it.
  8. dbickford
    dbickford Tele-Afflicted
    Morgan, Vermont
    Finally. Words of wisdom.
  9. KevinB
    KevinB Doctor of Teleocity
    SC (S)lowcountry
    Agreed 100%!
    You can really overthink this stuff :eek:
  10. Pete W
    Pete W Tele-Meister
    It's the under thinking which causes the problem, too many people take strings off or loosen the truss rod off for extended periods of time and DON"T check the possible movement of the neck.
  11. telex76
    telex76 Doctor of Teleocity Silver Supporter
    Fort Worth,Tx.
    How long you got?
  12. Pete W
    Pete W Tele-Meister
    How long you have depends on various things such as humidity changes and different necks have varying levels of stability.
    For example a lacquered neck tends to absorb and rid itself of moisture much slower than an unfinished neck.
  13. Williams
    Pasadena
    I'm leaving it off for about a month or two until my next paycheck. It is currently summer weather here in So Cal so nothing too drastic...
  14. Geo
    Geo Friend of Leo's
    Hendersonville, TN
    Keep it in a good moderate climate area that is not too humid, dry, cold or hot.
