cyclopean
Pedal based is better because it’s easier to swap out than replacing a tank or trying to figure out how to mod the amp circuit to put trem in.
Thanks to everyone who voted and commented.
It amazes me that some companies charge $1,500 - $2,300 for a standalone tube reverb and tremolo unit (e.g. NO amp), and you can get a nice Fender 68 Princeton Custom tube amp (with a tube rectifier) that has onboard tube reverb and tremolo for $1,200(!)
As it occurs in various amps, like the Fender Deluxe Reverb, Fender Princeton reverb, etc.
Thanks for participating.
Oh yes, oh yes. I worship at the alter of hand wired, all tube. A true thing of beauty. Mercy, mercy!!!Well, if you're referring to something like the Victoria Reverberato... these are in a different league. Much more complex circuit, more control, tones you can't get any other way.
There's a reason Fender stopped making the harmonic trem circuit. Too expensive, too time consuming, too much space needed on the circuit board, and likely too tricky to dial in on a production line. Very sensitive to actual component values.
According to Mark at Victoria, these are easily the most labor intensive product. Having built one myself, I wholeheartedly agree. I'm glad to have done it once, but never again. After that experience, $2k seems cheap.
Here's mine:
I quite like the tremolo on my PRRI, but I’m also quite satisfied to use a pedal. I prefer plate or room reverb generally, so I use my TC HOF instead. Still, it’s good to know that my PRRI has spring if I ever need it.
I seem to recall switching the true bypass off (using the internal dip switch) because it was causing a volume bump when I engaged the pedal. I can’t say that I noticed any tone suck.I returned my HOF. To me, it was a tone-sucker. Maybe I needed to run it with a buffer unit?
If you care to count my 2 cents (?), that looks like nice work and a labor of love. You are more of a connoisseur of tremolo than I am.Well, if you're referring to something like the Victoria Reverberato... these are in a different league. Much more complex circuit, more control, tones you can't get any other way.
Here's mine:
