How does a G&L Z-Coil work (i.e., how does it cancel noise)?
Discussion in 'Just Pickups' started by Golem, Jul 23, 2019.
  1. Golem
    Golem Tele-Holic Silver Supporter
    United States Of America
    I know they share some of the features of other MFD type G&L pickups, but they've also got the offset 3X3 coils to achieve a noiseless design. They don't really sound quite like anything else I've tried and I do find they have their applications (although not the best choice for someone who wants the kind of single coil chime my Silver Sky has).
  2. Golem
  3. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    2 Coils are RW/RP, wired in series. Noise entering the pickup is phase cancelled. Because the coils are not side by side, but each is sensing a separate set strings, the aperture is still narrow giving a brighter, clearer tone with a narrower Q than a full humbucker.
    This is exactly as implemented in the Precision bass and Fender XII.
    AAT65, teleaddicted, Dan R and 3 others like this.
  4. maxvintage
    maxvintage Friend of Leo's
    Arlington, VA
    yes exactly like a p-bass pickup
  5. Golem
    Thank you. I did notice they liked a bit like bass pickups Fender designed, but wasn't sure of the principle behind its design.
  6. sothoth
    sothoth Tele-Holic Double Platinum Supporter
    Kepler-186f
    Actually can someone explain how that works if the RWRP part of the pickups aren’t sensing the same string? If I have two single coil pickups wound RWRP and my toggle switch on the middle position, it phase cancels because each string is sensed with both phases. That makes sense to me because standard HBs do that. The offset coils don’t make sense to me. Maybe I should look for a diagram of how they wind them and it will make sense...
  7. Guitarteach
    The key thing is that the hum they cancel is in the environment not coming from the string.
    The two coils are independent and the string signal component is kept in phase across the strings by a polarity change but the environmental radio noise is cancelled by the two coils being out of phase.
    They basically split the duties into two halves rather than combine them like a stacked humbucker. This keeps the single coil character but eliminates the hum. The precision bass pickup mentioned makes it more obvious as it comes in the two parts.
    Look at dummy coils too. I use a magnet free pickup in the control cavity of my hum prone P90 guitar to cancel environmental hum. The dummy coil can be some distance from the strings.
    0utputXfmr likes this.
  8. sothoth
    Kepler-186f
    Ok I get it. Is there a downside to this type of hum cancelling (tonally or otherwise) aside from the strange appearance? Curious why more aren’t wound this way? It seems to be the best of both worlds other than being an obvious irritant to vintage purists :)
  9. Guitarteach
    You answered your own question. People don’t like change or difference.
    The marketing and beliefs around ‘tone’, make people fear changing anything in the formula they believe works.
    TeleTucson and 2 Headed Goat like this.
  10. sothoth
    Kepler-186f
    Well they ARE kind of ugly :)
    I feel like I have to buy a new guitar now just to see what they sound like.
    The only real problem I see, and maybe isn’t really a problem, is they have no 3rd party alternatives if you don’t like the stock winds.
  11. teleaddicted
    teleaddicted Tele-Holic
    Roma Urbe
    How did you wire the dummy coil?
    What is it's resistance?
    I have a Blacktop Tele with SD Phat Cats that could take advantage of this application.
  12. Guitarteach
    It was a stock Ibanez single coil (middle pickup from a S series) I had spare. I simply removed the magnets and put it in the control cavity. I did not measure the resistance but it would not have been astronomical. It kills around 90% of the hum.
    I wired it on an on-on-on mini switch for series, off and parallel operation with the output from the switch going to the volume. The wiring is the same as wiring a humbucker for single, parallel and series, just with the coils in different places.
    When setting it up, you can rotate the pickup 180deg to find the orientation that cancels the hum.
    I love it in parallel, it takes a little of the P90 fatness out and gives me a perfect fat strat, jangle tone I can switch too.
    It’s in my number one and the main reason I can use it for every tune.
    https://www.google.co.uk/search?q=dummy+coil+wiring&ie=UTF-8&oe=UTF-8&hl=en-gb&client=safari
    teleaddicted likes this.
  13. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    Same basic concept as a Mustang Bass pickup (which is itself a miniaturized version of the second style of P Bass pickup), but with MFD design/construction and a single-piece cover. Basically, it's a split-coiled and staggered S-500 pickup, with each half being RW/RP from the other.
  14. rigatele
    rigatele Tele-Afflicted
  15. Golem
    I'm certain you can get people to modify the pickups with different magnets, and different amounts of turns of wire... I found a thread when I asked about this where someone said Fralin or Lollar will do it (can't remember which one). I'm sure the custom winder I use would do it. You're not wrong that no one is making something with this exact footprint though. Probably some sort of trademark protection or lack of demand (or both?).
    I've tried two guitars with these pickups in it, the first was a really beat up Tribute that sounded less than amazing, and the second the custom build G&L Commanche I now own which sounded amazing. I agree that if you buy a Commanche or an ASAT Z-3, you should be buying it for the pickups it has in it. Swapping isn't as easy as it is with more common pickups.
  16. darren7
    darren7 Tele-Holic
    Toronto
    Simple answer: It's a humbucker.
  17. 0utputXfmr
    0utputXfmr Tele-Meister
    York, Pennsylvania
    The Epiphone Blueshawk (and maybe the earlier Gibson version of the late 90's-early 00's) has a dummy coil installed inside a body cavity located between the front and rear P-90's. From pretty much all accounts, it seems to cancel the hum rather effectively.
  18. sothoth
    Kepler-186f
    Is there a downside to this approach? Wonder why it’s not more common.
  19. Golem
    The Illitch noise-canceling backplate takes this approach and it's getting popular on high end guitars.
  20. rigatele
    Yes there is. A dummy coil with close to the same diameter as a pickup must have as many or almost as many wire turns as a pickup. Putting that in circuit, whether in series or parallel, substantially changes the response and thus the tone. The Illich device minimizes that effect by using a very low impedance coil, which has to have a very large diameter to perform the same function. It works brilliantly, but few manufacturers want to pay royalties on the patent. It's also adding design complexity to solve a problem that has other, simpler solutions like RWRP wiring, stacked coils and even just accepting plain old humbuckers, or accepting a little noise!
    0utputXfmr, Golem and teleaddicted like this.
