bluesfordan
this, this and so much this. My first trip to SC, in April, I'd go into stores and restaurants and see my breath. It was too damn cold, then you go back outside and your skin felt like it was going to peel and slide off like you were a blanched tomato. My glasses would fog up going outsideOne thing that makes some people feel the heat in Phoenix more than they should: they turn their AC ridiculously cold. Like 68 degrees…then when they step outside they get blasted with a 45 degree temperature swing. Instead, run the AC about 80 or so, and it’s not so brutal stepping outside; then when you return inside it still feels refreshing.
I've always felt a/c was just to dry the air out and reduce the differential, not set a immutable low temperature. I've talked to people in TX, who set their AC to 60 or 62 degrees, no matter what the temperature outside is. I'd be wearing sweaters, hats and gloves if I had to live that way. The Energy Council (or whatever it's called) told the Texas people last week "we're going to have rolling blackout if you don't put your thermostats on 78 degrees". It was not well received.
