How Do I Get This Finish?
Discussion in 'Finely Finished' started by SmashingPumpkin, Apr 10, 2015.
  1. SmashingPumpkin
    SmashingPumpkin TDPRI Member
    London
    Hi everyone,
    I am in the process of building a Fender Telecaster Thinline and this is the finish I am looking for.
    The wood is Ash
    As you can see it is still semi-transparent and the finish is orangy.
    Would anyone know how I can get this finish?
    And also for the headstock.
    Many thanks
    Jake
  2. funkymann1
    funkymann1 Tele-Holic
    Cooper City Florida
    im pretty sure they just tinted the paint with amber or yellow tint...i would have both on hand & shoot some scrap first to try & get it close...
  3. SmashingPumpkin
    London
    Okay! I will try that thank you. What type of paint would you recommend?
  4. SmashingPumpkin
    London
    Does anyone else have anymore ideas?
  5. Kitsune_12
    Kitsune_12 TDPRI Member
    Belfast, Northern Ireland
    You can get rattle can nitro lacquer that is amber-tinted. I think it is normally used for maple necks to get that "vintage" colour, but it might work for an ash body. Perhaps testing it on some scrap wood would confirm if it was the right colour for you.
  6. R. Stratenstein
    Loganville, Ga.
    Since you are in the UK, check out Rothko and Frost. Fellow Brit Barbrainy reports good experience with them, and knowledgeable, friendly advice. They apparently do give good advice, as Brainy produces great looking guitars, until he sands off the latest effort, in search of perfection, but that's another story!
  7. SmashingPumpkin
    London
    Butterscotch Blonde Nitrocellulose Lacquer
    Hi,
    Thank you very much your absolutely right. I found a company in the uk called Northwest Guitars who offer a nitro Lacquer called Butterscotch Blonde. I think this is as close as I'm going to get.
    What do you think?
  8. SmashingPumpkin
    London
    Thank you I will check them out! :)
  9. SmashingPumpkin
    London
    Thanks again, I looked into them and think I've found an even closer fit.
    Thanks for the advice
    Jake
  10. DrASATele
    North of Boston
    Funny I was going to say it's a straight up tint for the thinline not the BSB type finish.
    Post some pics if you can!
  11. Mike Simpson
    Gilbert, AZ (PHX)
    That looks like amber clear to me.
    This is nitro over shellac.
    I mixed garnet and blond shellac flakes to adjust the color. Garnet was too orange so I diluted it with blonde and added a little honey amber dye. The topcoats are Behlen clear nitro.
  12. Tinribs
    Tinribs Tele-Meister
    London, England
    I've bought the bsb from Manchester guitar tech. Will be spraying soon. That pic you posted isnt the colour I'm expecting.
    I originally sprayed my ash tele with the cheapest poly I could find and after about a year it went that amber colour you are after
  13. Mike Simpson
    Gilbert, AZ (PHX)
    Butterscotch blonde is supposed to be a translucent white that has yellowed with age. This blocks out the wood grain except the dark grain lines. The problem I have with most BSB finishes is they are too orange.
  14. dazzaman
    dazzaman Tele-Afflicted
    Gent, Belgium
    Although probably not the way it was done originally, it would be very easy getting that colour with shellac as Mike Simpson suggests. I am sure he is correct that the original you are seeing is just clear which has changed over time.
  15. SixShooter
    SixShooter Friend of Leo's
    Cincinnati
    Try it on scrap first. I have tried several tinted clear lacquers and found them all to be too bright orange or yellow. Also base coat color can change after applying several coats of (non-tinted) clear lacquer so make sure your test includes covering with some non-tinted clear.
