How do I clean this Tweed case thats been affected by humidity.
Discussion in 'Bad Dog Cafe' started by Rainbowberry, Sep 26, 2021.
  1. Rainbowberry
    Rainbowberry TDPRI Member
    Philippines
    This is the case of a custom shop nocaster my friend has. It was stored in an environment with very high humidity... any idea how to clean this?
  2. Deeve
    Deeve Poster Extraordinaire Silver Supporter
    Ballard
    Ewww
    Camo-inspired...
    Start w/ uv?
    Advance w/ baking soda & stiff dry toothbrush?
    Add finely ground Moss-be-Gone?
    Good luck?
    Skydog1010 and Mark617 like this.
  3. Boreas
    Boreas Poster Extraordinaire
    Adirondack Coast, NY
    What does the inside look like?
    Mildew is nearly impossible to remove - both the stain and the SMELL. People usually start with a 10% bleach solution on the exterior to kill it. Then scrubbing. Inside also must be treated, and is nearly impossible to eradicate the smell. But leaving outdoors in bright sunlight can help. Probably a thousand YouTube videos of different methods that don't work.
    If the guitar is unaffected, I would probably replace the case, otherwise the guitar will always stink as well. But no harm in trying. If the mildew has penetrated very far, you are scrod.
    nojazzhere, Cali Dude and loopfinding like this.
  4. EsquireOK
    EsquireOK Poster Extraordinaire
    U.S.A.
    It's totaled.
    Best bet? Lacquer over it with an opaque color. Call it "custom."
    Deeve likes this.
  5. Midgetje94
    Midgetje94 Tele-Afflicted
    Take it to an upholsterer (or redo it yourself)
    nojazzhere likes this.
  6. Boreas
    The stains look kinda relicked, but the stink would be a deal-breaker in my case (no pun intended). Some people are very allergic to mold spores which would likely be lurking inside as well.
    Coffeemutt, nojazzhere and Midgetje94 like this.
  7. Fendereedo
    Fendereedo Poster Extraordinaire
    Sunny Suffolk UK
    This^^^^
  8. Midgetje94
    I’ve always wanted to get one done in Louis Vuitton. Not because I’m a fan of the company. But Keef has one done
    Coffeemutt, Boreas and Fendereedo like this.
  9. Recce
    Recce Friend of Leo's Silver Supporter
    Northern Alabama
    Remove the guitar. Carefully carry the case outside to the trash receptacle on trash day. Drop it in. Get a new one from one of the many companies that carry them.
    Boreas likes this.
  10. Antoon
    Antoon Tele-Afflicted
    Low Lands
    I would not ditch it because of the stains. If it is not lacquered you may be able to bleach it and then dye or coat it with amber lacquer?
    Boreas likes this.
  11. lammie200
    lammie200 Friend of Leo's
    San Francisco
    Try some carpet cleaner on it and them leave it out in the sun.
  12. Lone_Poor_Boy
    Lone_Poor_Boy Tele-Holic
    Colorado
    Good lord. I've never seen anything like that. Was it stored on the bayou? Loving my dry Colorado air here, where my towels don't smell mildewed after one shower.
    Skydog1010 and Boreas like this.
  13. Boreas
    Allotta flooding going on.
  14. Alamo
    Alamo Doctor of Teleocity
    Berlin
    There's always the sun ;)
  15. Lone_Poor_Boy
    Colorado
    I get that but this reads as 'stored for some time' and a case doesn't go that bad from one event. I've recovered a large industrial facility after a flood came through and every basement flooded, every ground level room had 4 inches of mud in it, and every MCC had drops of moisture hanging throughout. Pull it out, blow it and dry it off.
  16. arlum
    arlum Tele-Afflicted Platinum Supporter
    O'Fallon, MO
    So I'm hoping there was no guitar inside the case when it flooded? :cry:
  17. Dennis Perusse
    Dennis Perusse Tele-Meister
    Amesbury Mass
    Going on a long shot here but if I owned that case I would first try to clean it with a very diluted bleach solution and scrub it first. See where that takes you followed by leaving it in the sun for a while. Then, if that doesn't do to much, hit it with a pressure washer to see if it takes off the rest of the gunk followed by leaving it in sunlight again to see what that'll do to it. Again, grasping at straws but you'd be no worse off then by just tossing it if the results are a no go.
    The only thing else would be to take some dimensions down and use as a template to build one for yourself if you like to build stuff. Best of luck in your efforts.
  18. Alamo
    Berlin
    No one should ever toss a Tweed case, no matter the condition.
    there will always be a taker!
  19. Wallaby
    Wallaby Friend of Leo's
    Here
    Maybe an ozone generator for the mildew and odor. For the mottled discoloration I am not sure, but I wonder about trying a soft bristle brush and a vacuum first to see if anything will dislodge from the weave.
  20. Mark617
    Mark617 Tele-Meister
    Massachusetts
    Order a new one from Stratosphere
