I have a Victoria 20112. It’s an earlier model with just the on/off switch, no standby. I have it plugged into a good quality power strip, along with 2 other amps and my pedal board. I’ve been swapping speakers in and out of the Vic the last couple days so it’s been open and had the tubes pulled and re-installed several times to accommodate the speaker swaps. I had been swapping the lead back and forth a/b/cing my 3 amps, and turned the Vic off to play through my Marshall. When I went to turn the Vic back on I got a little “bite” from the toggle. I also noticed that after the last speaker swap it was hissing/humming loudly, even at idle.
Any INFORMED ideas as to why I got shocked, and what I might want to look for so I don’t get bit again?
