How Can I Measure a Pickup in Detail?
Discussion in 'Just Pickups' started by tedtan, Sep 10, 2018.
  1. tedtan
    tedtan Tele-Meister
    Kansas City
    I have a Fluke 87 iii that serves well for measuring DC resistance and (milli)voltage, but I also need to measure the inductance and resonant peak of a pickup. I assume that I will need additional tools to accomplish this, but would be happy if my existing DMM can pull this off.
    Any thoughts?
    Also, is there anything else I should measure in order to help quantify a pickup's tone?
    Thanks.
  2. uriah1
    Around
  3. Inglese
    Inglese Tele-Meister
    Italy
    The point is that a pickup is not an inductor thus inductance varies with frequency.
    I guess measuring It at 1kHz is representative enought.
  4. Antigua Tele
    Antigua Tele Friend of Leo's
    west coast
    Here's my guide http://guitarnuts2.proboards.com/thread/7723/measuring-electrical-properties-guitar-pickups
    Im not familiar with the Fluke 87, but it would need to allow inductance testing at 100Hz, give or take, and simulate a series RLC circuit. Meters like the DE-5000 can do it and are fairly cheap.
    If you know the inductance you can determine the peak freq to a close by making some safe assumptions about the capacitance. If you name the type of pickup, I can probably tell you what sort of capacitance to expect from it. Since the guitar cable supplies most of the capacitance, its not necessary to be to super accurate.
    PingGuo likes this.
  5. tedtan
    tedtan Tele-Meister
    Kansas City
    Thanks for the responses, guys.
    And I can tell that Antigua Tele has put a little thought into this. :D That's what I was looking for.
    As for pickup type, I have several PAF-ish humbuckers that I like in various six string guitars (different manufacturers, different magnets, etc., but all PAF-ish). I am trying to get a ballpark idea of what I like about these so I can find a similar 7 string pickup for my 7 string guitar. unfortunately, most 7 string pickups are overwound, have ceramic magnets, etc., plus they will have a wider bobbin, so it's a bit of a challenge.
  6. Antigua Tele
    west coast
    Consider getting the hottest 7 string pickup you can find, then wire it in parallel. If it has a ceramic magnet, just lower the pickup a little to approximate a pickup with a weaker magnet.
    rigatele likes this.
  7. tedtan
    tedtan Tele-Meister
    Kansas City
    That's an idea I hadn't thought of, so I'll definitely keep that in mind.
    I also traded a couple of stock Ibanez 7 string pickups for a set of set of Dimarzio PAF 7 pickups (which have ceramic magnets for some reason), so I'll check those out, too. If I can't get them to work, I may try swapping magnets around to see how that changes things up.
