How are you getting your favorite Tone at the moment?
Discussion in 'The Stomp Box' started by RetroTeleRod, Aug 30, 2019.
  1. Grateful Ape
    Grateful Ape Tele-Holic
    I could work with that rig. Good call.
    Bowpickins likes this.
  2. Grateful Ape
    It's surprising what good results can be found in a recording situation using inexpensive tools.
    Live, if I can actually hear myself over the horns I'm happy....
  3. jim777
    jim777 Tele-Meister
    South New Jersey
    Main sound is the 2nd of the 4 positions on the Baja tele (towards the neck) into an AX8 set to the"EJ Clean" sound (bit of chorus and delay) into my Mark IV clean channel. Fantastic sound
    RetroTeleRod likes this.
  4. VintageSG
    Yorkshire
    Today, the planets aligned. I'm in the midst of an ankylosing spondylitis flare up, and yes, it hurts just as much as getting your head around the pronunciation does. Movement hurts, but I can 12 bar, just not go up and down the neck much. I'm also in the midst of yet another Pops Staples kick. I heartily recommend studying how Pops plays. My being forced to make the most of limited left arm movement focussed the mind somewhat.
    CV 50's --> Tremolo --> JCA20H --> 2x10" ( with an attenuator for domestic harmony )
    Nothing else. The amp set with a little crisp on the pre-amp, and a little compression on the power stage. So close. Add in a subtle amount, and I mean subtle, of reverb, not my usual gobbets of surf pastiche, and at last, there's the Pops sound.
    CV 50's --> Tremolo --> Spring King --> JCA20H --> 2x10" ( still with an attenuator for domestic harmony )
    The Spring King has a very short tray, so Danelectro added a fast repeat to the front end of it. Normally, it irritates me, but today, the pulse of the tremolo and the shimmer of the reverb with the amp on the verge of dirt got me there. Heaven. Pops has fascinated me for years. Today, I felt I honoured him.
    To draw a parallel, Colin Chapman explained the Lotus philosophy with 'Simplify and add lightness'
    One tone, and work it until it complies.
    Beaubien66 and RetroTeleRod like this.
  5. Rusty Shackelford
    Rusty Shackelford TDPRI Member
    Fort Lauderdale
    Tele neck pup tone around 2-3/10 > CompROSSor > PRRI
    I like it warm and fat
  6. Frontier9
    Frontier9 Friend of Leo's
    Greetings from Sunny New Jersey
    Bad Monkey set to a very mild mid boost, light gain - goose with an 8 band EQ pedal with an upper mid/treble boost when the feeling is right. Add Telecaster and a clean Fender solid state amp. Cheap and cheerful, great sound.
    kevsonic and RetroTeleRod like this.
  7. nic'o'caster
    nic'o'caster Tele-Afflicted Ad Free Member
    Middle Earth
    Any of my Teles -> Keeley Fuzz Head set rather clean -> Normal channel of a '64 Custom Deluxe Reverb
  8. Beaubien66
    Beaubien66 TDPRI Member
    Fender Vintera 60s Tele + Princeton Reverb.
    Clean or with Boss Chorus CE2, Boss Blues driver, Fuzz... Drum beat : Garage Band.
    I did a short track before I got time to Set up the guitar. Slightly off intonation... so I did something in the manner of Roger and the Gypsies (Pass the hatchet) :) :))
    https://w.soundcloud.com/player/?url=https://api.soundcloud.com/tracks/678903522?secret_token=s-tCRq0&color=#ff5500&auto_play=false&hide_related=false&show_comments=true&show_user=true&show_reposts=false&show_teaser=true
  9. Bill
    Bill Poster Extraordinaire Ad Free Member
    London
    jaycoyoyo, heffus, 4pickupguy and 2 others like this.
  10. schenkadere
    schenkadere Friend of Leo's
    NY
    Guitar(Jackson Soloist/Dean V)>Mooer Yellow Comp>Donner Boost Killer>Donner Yellow Fall(effects loop)>Randall Diavlo 5W 1x12 gain at noon...adjust guitar volume as needed. Not including the guitars, this is an amazing sub $500 set up. Honestly the best tone I've had in years.
    Comp almost always on just a tiny touch above unity...ride the guitar volume...stomp on the boost for more gain and a bit of bass cut to tighten it. Delay always on with relatively short delay and just a few repeats. Cheap and delicious!
  11. wulfenganck
    wulfenganck Tele-Holic
    Seligenstadt, Germany
    With this (Ibanez Artcore AR75 with some specifications):
    This (Hughes & Kettner Edition Tube 25th Anniversary):
    And this (unchanged since 1 year):
    Best tone I ever had since starting somewhere in the 80s.
  12. juxtapolice
    juxtapolice Tele-Holic
    Jersey City
    I have two right now
    Es 335 straight into my Swart AST. That guitar has throbak pups in it that sing so sweetly, when the amp is turned up it's instant feedback on any note
    Second is my custom shop 51 Nocaster straight into a Swart 6v6se cranked.
  13. codamedia
    Western Canada
    My gear changes over the years, but my favorite tone(s) have not.... I accomplish them the same way, given just a few basic items.
    In sequence...
    • Telecaster... most often the bridge pickup
    • TS style overdrive (kicked in for big solos)
    • Soft overdrive
    • Always On Compressor... gently applied
    • Tremolo
    • Delay (sometimes set to slap, sometimes set to longer setting or tap)
    • Normal Channel of a Blackface Fender
    The compressor location often baffles people. IMO... it's logical. My guitar hits the soft overdrive before the compressor... this allows me to get more dynamics from the dirt - then just smooth it out with the comp. When I don't use the overdrive my guitar hits the comp first for a more traditional country snap. The TS is only used for big solo's... always in conjunction with my soft overdrive.
    I don't care if I'm given a traditional pedal board, a low cost Multi-fx, or a high end Helix/Kemper/Fractal.... my primary chain never deviates.. and I always get my favorite tones.
    4pickupguy and RetroTeleRod like this.
  14. richey88
    richey88 Friend of Leo's
    philly suburbs
    LPJ Dude here ( surely I posted here before) SO much you can do with the volume knob and some OD. Practice last night was fuzz (v1 Dano Cool Cat) reverb and the volume knob . Pro Jr IV just keeps sounding better every jam.
  15. 4pickupguy
    4pickupguy Doctor of Teleocity Silver Supporter
    Fort Worth, Texas
    Totally agree! Comp has always worked better for me after drives for the reason you stated.
    codamedia likes this.
  16. Cerb
    Cerb Tele-Meister
    Sweden
    Pretty sweet right now is P90 SG into Quilter Overdrive 200 with some mid 90's Ibanez delay pedal in the FX loop, just a little slapback delay. It all comes out of a 1x12.
  17. Dan German
    Dan German Poster Extraordinaire Silver Supporter
    Left of the Left Coast
    Logan t-style with Keystones (or ‘65 Danelectro Convertible, or Godin 5th Ave with ‘50s DeArmond Guitar Mike pickup) into Roland Funny Cat (Soft Distortion Sustainer side only), then Bad Monkey with no gain, for clean boost, then ‘70s Bad Stone used manually for voicing, then a Danelectro Cool Cat Tremolo, into a Micro Terror driving the 6” speaker of a ‘60s Harmony amp.
    Don’t judge me.
  18. dombar335
    dombar335 Tele-Meister
    Pennsylvania
    Finally achieved a great P&W guitar tone that has eluded me for a while.
    Squier Classic Vibes Tele - bridge position, middle for some arpeggios
    Vox Ac10 set to the edge of breakup, Snouse BB2 as an always on light overdrive. Use my Caline Pure Sky to boost it for a medium OD, then a Rat for a heavy OD.
    Nemesis Delay set to tape (dotted eight most of the time of course). Then a HOF2 for reverb (Usually use the Church setting but recently switched to Plate and am loving it so far)
  19. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    I'm a big fan of Plate reverb. It's my go-to for clean tones. Otherwise maybe a little slap back delay if I'm going for a Rockabilly vibe. For overdriven sounds I just prefer them dry. Sounds like you have a nice rig there. I would love to get my hands on a AC-10!
    dombar335 likes this.
  20. neilybob100
    neilybob100 Tele-Meister
    Fernandes ST-50 Strat -> Suhr Rufus Reloaded Fuzz pedal -> Peavey JD30-T amp on either with clean or dirty channel with the boost engaged. Turn the amp up to 6 for a smile from ear to ear. [emoji1]
    Sent from my CLT-L29 using Tapatalk
