House Wiring Problems
Discussion in 'Shock Brother's DIY Amps' started by ArcticWhite, Sep 20, 2020.
  1. Cpb2020
    Cpb2020 Tele-Meister Silver Supporter
    New York
    One thing you can try is to turn off all the breakers, but for the one that your amp is plugged into (assuming your other electronics, e.g. modems, are not all on the same line). If there is no noise then turn the other circuits on one by one to see what circuit may have an offending frequency.
  2. String Tree
    String Tree Doctor of Teleocity Ad Free Member
    Up North
    I owe you an Apology for not seeing ALL MY AMPS in your first Post.
    I mistakenly, somehow, was under the impression it was only that amp.
    It sounds like Capacitors discharging somewhere.
    The fact that it makes that noise with everything else turned off is pretty weird.
    It could be something being fed to you from the Power Grid.
    It is no Secret that the Pacific Nowthwest Grid has been under a LOT of strain as of late.
    As a sign of total desperation, is there any chance you could plug it in at somebody else's house?
    Doctorx33 and ArcticWhite like this.
  3. EmWeAh
    EmWeAh Tele-Meister
    Germany
    Are powerline adapters present? Any chance you might get your hands on a power strip with built-in rfi filter?
  4. ArcticWhite
    ArcticWhite Tele-Afflicted
    Portland Oregon
    No powerline adapters.
    I've turned off every surge protector and computer in the house.
    I haven't yet turned off all the breakers except for one. Will try that tomorrow if possible
    King Fan likes this.
  5. King Fan
    Salt Lake City
    I assume you also unplugged your new modem for this. We should all probably do that once a day; sometimes I think I should do it for 23.75 hrs a day. :)
    This is the weakest possible hunch, but the noise vaguely suggests a fan, which makes me wonder about electric motors / compressors / etc: Fans, AC, fridge, I dunno.
    awasson and ArcticWhite like this.
  6. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    There is definitely a time-based component (non-random) to the noise that cannot easily be ignored...
    awasson and King Fan like this.
  7. awasson
    awasson Poster Extraordinaire Silver Supporter
    Vancouver
    Where’s your cell phone and is the modem and router off. Laptops, desktops, electronic ground fault breakers? Did they upgrade your meter to a digital one?
    My amp picked up my cell phone and if it weren’t for the repeating cycle, I wouldn’t have known what it was. It sounded similar but had a high pitch component to it too.
    ArcticWhite likes this.
  8. SacDAve
    SacDAve Poster Extraordinaire
    Rocklin Ca.
    I would take some Amps to a friends house and try them (maybe a couple friends houses) that would rule out the Amps. Also if you go into the main panel make sure all the all the ground & breaker connections are tight if you feel safe doing that.
  9. ArcticWhite
    Portland Oregon
    My meter is difital
    Okay, so today I flipped off every breaker in the panel except for the dedicated garage circuit and plugged in there. Cellphone in the basement.
    Same annoying chattering sound is present.
    Tomorrow I will tighten the grounds inside the panel.
  10. Cpb2020
    New York
    Ok, so it may be a house grounding issue, coming through the power line itself, or outside the house (e.g., a power line transformer). You’ve gone beyond my abilities.
  11. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Sounds to me it may be noise in the AC supply created by a switching power supply (MOSFETs) somewhere in the house.
    To see if it's the amp, your environment, or your AC power, take your amp next door and ask the neighbor if you can plug it in to do a test. That will help rule out several things as a possible cause.
  12. john_cribbin
    john_cribbin Tele-Afflicted
    London
  13. ArcticWhite
    Portland Oregon
    Peegoo, the house was built in 1952.
    I switched all breakers off, except for the dedicated garage circuit.
    What sort of MOSFET would we be talking about?
  14. Peegoo
    Usually something controlling a motor.
    But if you had all the breakers off, then it's not that.
  15. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Any switching power supplies, he's talking about devices on the house circuit not the circuit wiring itself.
    Devices at a neighbors house can do this too. Like grow lights for example... Tesla battery chargers...
  16. Cpb2020
    New York
    One other thought. Do you have access to an inverter that can run off a car battery handy? (I do as I run amps off a 12v battery when necessary). Or a car with a 120v outlet? (One of my cars does).
    If you still hear the noise using those then it isn’t the power line itself or ground, it is “environmental” (e.g. electromagnetic waves coming from a transformer or maybe a neighbor’s property).
  17. awasson
    Vancouver
    I wonder if it’s the digital meter. Ours does some weird dimming action in the summer months that the old school analog one never did.
    ArcticWhite and sds1 like this.
  18. D'tar
    D'tar Friend of Leo's
    WNY
    https://www.tdpri.com/threads/200-hz-hum-in-my-garage.1023730/
    By now I feel you are comfortable with mains voltage and wiring. If this were me and I did not own a scope, I would wire in a NEW breaker and NEW short dedicated circuit to a properly wired three prong outlet right at the distribution panel and observe for the same issue. You seem to be riddled with old house wiring issues. That is quite a bummer and something a recording artist can not be bothered with each time you want to perform and record.
  19. Telenator
    Vermont
    Are you running a stand alone or ceiling fan in the room?
    I was at a rehearsal in a guy's house where he was running a ceiling fan and the flutter sound almost drove me crazy until I figured it out.
  20. ArcticWhite
    Portland Oregon
    Read the thread.
    sds1 likes this.
