Hot/cold water conundrum
Discussion in 'Bad Dog Cafe' started by RLee77, Apr 13, 2019.
  1. getbent
    getbent Telefied Silver Supporter
    San Benito County, California
    this. when they work, they save water and bring happiness...when they don't.. not so much.
    drf64 likes this.
  2. Joe Sailor
    Joe Sailor Tele-Afflicted
    Longmont, CO
    william tele, RLee77 and Cheshiergrin like this.
  3. Cheshiergrin
    Cheshiergrin Tele-Holic
    Not there anymore
    RLee77 likes this.
  4. Paul in Colorado
    R.I.P. 2019
    Send a letter to Ask This Old House with that picture. You might get them out for an episode. Or an answer.
  5. Danocoustic
    Danocoustic Tele-Meister
    SE lower Michigan
    "Hot water heater".
    If the water is hot, why do you have to heat it?
    Be sure to use your PIN number at the ATM machine too.
    Harry Styron and David Barnett like this.
  6. Shuster
    Shuster Poster Extraordinaire
    Bulverde Tx.
    Alright, first that is a mixing valve at the bottom of the pic and it's bleeding across, and probably bad, chunk it!! Run new lines, right from the shutoffs to the faucet above and you have fixed the problem!
    You want hot water quicker, buy a circulating valve, connect it to the W.H. and run a 3/8 copper line from your water heater to the furthest hot water outlet and back. You'll have hot water in a 1/4 of the time.
  7. RLee77
    RLee77 Friend of Leo's
    Nevada
    Thanks for all the helpful comments! I figured it was some sort of advanced hot water thingy, but what I don't get is why in the heck is the cold water involved at all -- it seems to me that regardless of what you did to improve hot water availability, the cold water line should just go directly to the cold water tap.
    Anyway, I'll check for pumps at the water heater, and also for the possibility of dead batteries. So if I got this contraption working as it was designed to work, what would be the end result? In other words, what's it going to do for me? Do I even want it? Keep in mind this is just one bathroom sink... this arrangement is repeated at least 4 times in the house.
  8. drf64
    drf64 Poster Extraordinaire
    Ada, MI
    Happiness. Save water. what's not to like?
  9. Blrfl
    Blrfl Tele-Holic
    Northern Virginia
    Ideally, a recirculating hot water system would have a dedicated return pipe, making it a big loop with all of the faucets spliced in. The pump circulates water through the loop and is returned to the water heater to replace whatever heat was lost in the process. This is very common in large buildings where the system is long enough that you'd waste a lot of water and energy letting the hot water cool in the pipes and waiting for fresh stuff to reach the taps.
    Houses typically aren't plumbed this way, so retrofit systems use the whatsis you see under the sink. It has a valve that sends the hot water back to the water heater by way of the cold water line when neither is being used.
    You shouldn't have to wait for hot water and your utility bills will be a little lower.
    william tele likes this.
  10. trev333
    Coolum Beach,Australia
    is it an anti scolding system so you never get full hot water.... stops kids getting scalded maybe?...
    teleman1 likes this.
  11. RLee77
    Nevada
    Ok so I checked out the water heater, and there is in fact a Laing pump on top, which can be switched to on/off/timer modes. It was in timer mode, I switched it to always on so I can see what happens. It plugs into an AC outlet.
    Not sure yet if any batteries are needed under the sinks. Or if something is malfunctioning causing the cold water issue, or if the cold water weirdness is just the price you pay for the system. If the latter, I may elect to just do without recirculation. I assume if I just turn the pump to off it will behave normally and not affect the cold water system.
    Here’s the pump on top of the water heater... above the pump (not shown) is a large plastic reservoir.
  12. ClashCityTele
    ClashCityTele Tele-Afflicted
    Washington, UK
    I think that you need to call Harry Tuttle.
    RLee77 likes this.
  13. william tele
    william tele Doctor of Teleocity Ad Free Member
    Kansas City, MO
    teleman1 and RLee77 like this.
  14. getbent
    it should have an AC plug that you should plug into the wall. I have a system similar and, well, it is cool.
  15. RLee77
    Nevada
    I get it now, how it works and the trade off between fast hot water and cold water availability. I’ve turned it off for now. I don’t like not being able to get cold water. And you can’t have it both ways without a separate recirculating line.
    I suppose one could set the timer at a rate that would provide fast warm water in the winter, if you wanted.
  16. getbent
    that stinks that they didn't do it right. that installation looks a little janky... we have very cold water and hot water almost instantly... and it works...
