Hot/cold water conundrum
Discussion in 'Bad Dog Cafe' started by RLee77, Apr 13, 2019.
  1. RLee77
    RLee77 Friend of Leo's
    Nevada
    I recently moved into a new (to me) house in Reno. It’s appointed very nicely, high quality fixtures, great construction throughout. But several of the sinks exhibit very weird and inexplicable behavior when attempting to adjust the hot & cold water temp.
    I’ll start the hot water running with the left knob, it of course starts out very cold, and wait (a long time, but that’s understandable, it’s quite far from the water heater) until the water gets suitably hot. Then, I’ll try mixing in some cold from the right knob, and the water stays hot — really hot. In fact if I turn the hot completely off, the “cold” water stays just as hot... for a LONG time. Nearly as long as I had to wait for the hot to begin with. WTH? It seems like the longer I let the hot run, the more it negates my ability to get cold water. If I just run hot for a few seconds, then the cold water responds much faster.
    Looking under the sink, I see a suspicious gadget with the incoming hot/cold water lines attached (the big hoses), along with two outgoing lines feeding the sink’s hot/cold valves (smaller hoses). I’m guessing this mysterious widget is the culprit. What the heck is it? Is it broken, or is its purpose in life to prevent me from ever getting the water temp I want?
  2. Chunkocaster
    In space with Ziggy
    There should be two separate lines. Maybe that contraption is to stop the lines knocking or to isolate all water supply to the sink taps?
    I would route the cold feed directly to the cold tap and vice versa for the hot. Place a separate tap on each to isolate if needed. I would also seal that particle/chip board with something to stop it rotting from any moisture. If a leak appears around those hoses that board will swell up like a balloon and rot away after stinking the place up for a while.
    Try turning that black tap at the bottom of the doohickey. It might adjust the mix of hot and cold to each tap.
    Piggy Stu likes this.
  3. notmyusualuserid
    notmyusualuserid Friend of Leo's
    In the South
    You've got a hot and cold mixer valve under the sink as well as mixer taps (faucet) on the sink? Why? :)
    What is this flexible hose connected to BTW? It seems to go nowhere.
  4. Chunkocaster
    In space with Ziggy
    That looks like a feed for cold or hot. The line next to it running into the top of the contraption would be the other feed. Those two lines could be routed directly to the taps after enlarging the attachment nut threads via small independent taps. Then that contraption could be tossed in the bin.
  5. drf64
    drf64 Poster Extraordinaire
    Ada, MI
    Motorcyclists love to rant about the weird hacks the previous owners (PO) of their bikes did. Forums are filled with photos of inexplicable hacks and unneeded fixes. Surely there must be a home owner's version somewhere on the interwebs?
  6. Old Deaf Roadie
    Old Deaf Roadie Tele-Afflicted Silver Supporter
    Oregon
    I am guessing, and it is purely a guess because I am a tech & not a plumber, that the device is there to help justify the marketing that a previous homeowner fell for. I am also guessing that if you remove the device & plumb the lines direct to the faucet, everything will return to normal.
    nojazzhere and P Thought like this.
  7. Piggy Stu
    Piggy Stu Friend of Leo's
    You can choose between sorcery or ghosts, but it is def paranormal
    Who you gonna call?
    Chunkocaster likes this.
  8. notmyusualuserid
    In the South
    A plumber?
    Paul in Colorado, RLee77 and Wally like this.
  9. Piggy Stu
  10. Boubou
    Boubou Doctor of Teleocity Gold Supporter
    Montreal, Quebec
    Wtf.
    Rip that krap off.
    8barlouie, Mike Eskimo and P Thought like this.
  11. stxrus
    stxrus Friend of Leo's
    St. Croix, USVI
    What a kluge of idiotic plumbing
    Remove all of that mess. Get rid of the “stainless” supply lines. Flexible nylon is better
    Run a single supply line from each angle stop to the faucet’s intakes. Hot on the left - cold on the right
  12. trev333
    Coolum Beach,Australia
    That'd be the, errr? the Medusa valve, I reckon...o_O:D
    Rev Rhythm likes this.
  13. P Thought
    P Thought Poster Extraordinaire Ad Free Member
    Plundertown (Gasville) OR
    jeepers
    aerhed likes this.
  14. Tele-beeb
    Tele-beeb Friend of Leo's
    The Bluegrass
    Another thing to add to the TDPRI Lessons Learned:
    Never mix new plumbing with old plumbing.
    In other words, if I put in a new sink, I throw out the old, then it gets all new works to the source.
    Jimmy Owen and Mike Eskimo like this.
  15. jackal
    jackal Tele-Afflicted Gold Supporter
    mojave desert
    Check to see if there is a weird looking timing device attached to your hot water heater. There is a device that speeds up the hot water delivery to your far away faucets. When they go bad, strange things can happen. When mine failed, I got warm water at all times from the cold taps. I just turned the timer off. Simple flick of the switch.
  16. Piggy Stu
    Can someone who knows more than me explain the 4 way giraffe thing's purpose in normal life? Who wants that happening, ever?
  17. Blrfl
    Blrfl Tele-Holic
    Northern Virginia
    It's a valve that's part of a recirculating hot water system. You use it when the sinks are far enough away from the hot water heater that it takes forever to get hot water. Retrofit systems use the cold water line to get unused warm water back to the heater. Sounds like this one has a problem, either a failed valve somewhere or the pump isn't running.
    Cheshiergrin and Piggy Stu like this.
  18. Mike Eskimo
    Mike Eskimo Telefied Ad Free Member
    Detroit
    I’m not going to say how I know , but someone who knows less than me installed all of that...stuff.
    Everyone has their favorite supply line material. :rolleyes:
    The best one? Straightest route and no leaks.
  19. Piggy Stu
    I have made some ugly stuff like this in my life when fitting taps on a saturday night and can only reattach everything using inches and metrics and couplings left over in my garage
  20. telleutelleme
    telleutelleme Doctor of Teleocity Silver Supporter
    Houston
    Well you know what tool is required to remove it. The "Thingy".
    Also there is a guy called Bob on the label, call him.
    :rolleyes:
    Is it possibly a closed off line for a dish sprayer that wasn't used?
    Flat6Driver, JL_LI, RLee77 and 3 others like this.
