Honduran Mahogany & Nicaraguan Rosewood Strat:
Discussion in 'Tele Home Depot' started by Telemaestro, Jul 17, 2016.
  1. Telemaestro
    Telemaestro Tele-Meister
    Hartville, Ohio
    Poor lathe on the floor until I build a stand.
    Drill press beside the exit door.
    And what is slowly becoming my lumber storage area. More work to do there.
    Now if you see me working on something, you have a mental picture of where it all is.
    Cheers!
    -Austin
    lbridenstine and David_Maas like this.
  2. Telemaestro
    Hartville, Ohio
    I'm pretty excited because my tuners came in today, so I can see if I have the drill I need, or if I'll be needing to purchase one.
    I went with the Gotoh 510 locking tuners in chrome. Which will be a nice pairing with the Stetsbar trem.
    I also finally bought another set of 6" calipers to keep at home. Most of my measuring tools are at work, and all I had at home was an 0-1 mic, a 1-2 mic, and a 24" set of calipers. So, I got a nice used set of Mitutoyo vernier scale calipers from eBay.
    Measured the tuners, and the through post is 0.389" at it largest point at the base. [​IMG]
    So at .390" a 25/64" drill will work perfectly.[​IMG]
    Next I want to check the threaded bushing to see what size hole it will require.
    It measures 0.308".
    Unfortunately the closest drill I have it 5/16" which is .313". But, given that the next drill size down is a letter N which measures .302, a 5/16" will have to do.
    Okay, that's all. I know it's boring, but I really want to document all of the steps that I go through to create an instrument. And who knows, maybe it will help somebody!
    With the miterbox built, and the drills for the tuners worked out, I need to start thinking about building jigs for the truss rod route, how I want to radius the fretboard, how I want to carve the neck... When I moved shops, I literally threw out all of my jigs and templates. So, this build thread is going to include building everything I need to build this guitar. Hopefully it will be an interesting enough ride for y'all to stick around.
    Cheers!
    -Austin
  3. RLee77
    RLee77 Friend of Leo's
    Nevada
    What, you didn't build your own tuners?!?
    (just kidding... although from what I'm seeing you could!)
    Really looking forward to learning a lot watching this process.
  4. Telemaestro
    Hartville, Ohio
    Don't tempt me! I have considered it in the past, and someday I would like to, but time is always my limiting factor, I have access to almost an unlimited array of equipment, but for this build, I want to try to do everything from my home shop. I'm a hobbiest now, and I want to approach it that way.
    Cheers!
    -Austin
  5. Telemaestro
    Hartville, Ohio
    Okay, question... This is totally unrelated to this build.
    Do y'all prefer this:
    Or this:
    The first pic technically the cream is just masked off, but I'm tempted, and can easily paint over the cream to make it solid blue.
    -Austin
  6. Revv23
    Revv23 Friend of Leo's
    Michigan
    You have to post a "subbed" post! When I'm on my PC I sub in silence.
  7. fatcat
    fatcat Friend of Leo's
    Very Deep South
    The cream in second PIC looks awesome.
    ModerneGuy likes this.
  8. David_Maas
    David_Maas Tele-Meister
    Potsdam, Germany
    Cream all the way!
  9. Telemaestro
    Hartville, Ohio
    Maybe it's just me that hates it...
    In other news, I've decided to pick up a 7.85mm drill for those threaded tuner bushings. At .309, it will be a much better fit that the 5/16".
    Cheers!
    -Austin
    David_Maas likes this.
  10. David_Maas
    Potsdam, Germany
    Perhaps it'll grow on you with a suitable pickguard + the rest of the hardware.
    They make 7.85 mm bits? I've seen 7.5 mm and some ridiculous fractional inch sizes, but bits to the .05th of a mm, that's new to me. I'd imagine it's quite a feat to pick one up in the States.
  11. Telemaestro
    Hartville, Ohio
    Plan for the pickguard is back painted polycarbonate with the same color as the cove.
    No, I can have it here tomorrow from Grainger! :)
    -Austin
  12. callasabra
    callasabra Tele-Afflicted
    It has potential if creme will be part of a theme. I don't like it. Maybe a color other than creme would work.
  13. JGOCTO
    JGOCTO TDPRI Member
    Tega Cay, S.C.
    Wow! Well- it looks like you are doing a Fantastic job!
  14. Telemaestro
    Hartville, Ohio
    Yeah, I don't like it either, but the guy I'm making it for wanted it...
    -Austin
  15. JGOCTO
    JGOCTO TDPRI Member
    Tega Cay, S.C.
    How did you get all that equipment into your basement?- especially an 800lb. buffing machine! -LOL!
  16. Telemaestro
    Hartville, Ohio
    It's a walk out. The walk out door is next to the drill press. Still a 7" step down, but not too bad at all.
    -Austin
  17. Telemaestro
    Hartville, Ohio
    Thanks, by the way!
    -Austin
  18. Telemaestro
    Hartville, Ohio
    Speaking of that buffer, you might be a guitar builder if your friend buys you a pedestal buffer for your wedding gift! My friend and old business partner got this for me from a used industrial reseller as my wedding gift in 2013. When I got it, it had a 10hp 3ph motor on it, which although I had 3ph at the time, was way overkill. I've since switched it to a 1/2hp motor on a slack belt.
    -Austin
  19. callasabra
    Well then, it is his mistake. Carry on soldier.
  20. RLee77
    Nevada
    I'm with Callasabra, I like the accent itself, but cream seems to clash with the dark blue... a slightly darker color might work.
