Home-brewed paisley fabric
Discussion in 'Finely Finished' started by Mistahbrock, Oct 27, 2020.
  1. Mistahbrock
    Mistahbrock TDPRI Member
    Denmark
    Hello everybody :)
    I just finished a paisley fabric finish and I'm very happy about the result :)
    First I bought a unfinished fender neck from 2009, it was taken out off production due to a brown streak in the headstock
    the body is american alder, made to original fender 60ties specs, it was a little beauty, but it was to be covered with fabric so it wasn't a big deal.
    Then I glued on some silver and black/ blue fabric on the top and bottom, using a equivalent of titebond
    I live in Denmark where we have some real great glue manufacturers, as our climate is wet and windy
    Next I poured some poisonfree art resin on the top and after 24 hours of curing the bottom, using painter tape, which is not so great, as the resin made a few undercrawls ruling down the sides of the body = more sanding :(
    I had the body all flat using the small bubble level seen on the right op in the picture
    I used a crappy heat gun to get most of the air out the resin, it has broke apart five times but still works, little did I know how many would be left after curing, I got wiser...
    Resin overruns.
    In my infinitewisdom, I missed to cover the backhorn, so I did a crude repair with semihardened resin, some 12 hours late...
    Backshot with the silly repair ( which will be covered with the blackburst later )
    Top of the back
    radiocaster, G-52, gimmeatele and 5 others like this.
  2. Mistahbrock
    Denmark
    Ready for sanding and routing off edges with a roundbit
    Blackburst with first layer of Nitrocellulose spray lacquer
    I'm not all good at centering the string ferrule holes, dammit!
    Third layer of Nitro
    The pickups are from tone hatch. they are alnico 3 which pulls a little less in the string and have a nice overall clarity, I can recommend these :)
    https://www.tonehatch.com
    And I added an open top cover, mainly for the looks, but also a bit of shielding as well
    radiocaster, G-52, Flip G and 3 others like this.
  3. Mistahbrock
    Denmark
    I since added a customised control plate from rockrabbit
    this plate is made from titanium and features a slanted switch slot and the volume is moved a little back to gain more space for my sausage fingers grabbing for the knob, but I probably return to a standard, as my tiny brain is used to the standard tele specs.
    I like this look better though, and as we all know, telecasting is all about looks and nothing else... ;)
    And then I use a CTS 500K push pull potentiometer as a passive "boost" using a 100k resistor and a 300pf capacitor treble bleed in serial with the Hotwire, which dampens the output unless I pull the knob, blowing up to full output.
    As a live engineer I think I may have overdosed on guitar distortion and overdrive so I love this modification only beefing up the clean signal.
    But it can of course be set so the gain on the AMP only cranks when it's full on.
    Feel free to ask if there is any questions on this build :)
  4. Buckocaster51
    Iowa USA
    Admin Post
    Very nice
    Mistahbrock likes this.
  5. Mistahbrock
    Denmark
    Thank you :)
  6. bsman
    bsman Friend of Leo's
    Santa Clara
    What sort of tone-cloth did you use?
    Actually, really nice job there. :)
    SKEsq, Jim_in_PA and Mistahbrock like this.
  7. ReverendRevolver
    ReverendRevolver Tele-Afflicted
    Ohio (Nerk)
    Looks great
  8. Mistahbrock
    Denmark
  9. joe_cpwe
    joe_cpwe Tele-Holic
    WI, USA
    that's wild. good job.
  10. Crowcaster
    Crowcaster Tele-Holic
    North Dakota
    Very nice!
  11. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    It looks great. I myself wouldn't have gone to all the trouble to do the resin coating but it'll certainly hold up to a lot of wear and tear. It seems like that was pretty difficult to get right though.
  12. gkterry
    gkterry Tele-Holic Silver Supporter
    the Telecaster Forest
    Wow, that is beautiful! Very nice - really like the metallic look to the fabric too.
    Mistahbrock and tubegeek like this.
  13. Mistahbrock
    Denmark
    Do anyone in here know if this passive "boost" is out there ?
    I have been searching with no results and maybe I am the only one who likes this function.
    And thanks for all the credits
  14. Mistahbrock
    Denmark
    heh heh, the resin saved me lots of Nitro layers and some bucks.
    Besides from this, Nitro is always vaporising slowly so the resin will also expand the life of the finish.
    Its somehow similar the function of fullerplast.
    This is my first fabric finish, and it wasnt that hard, but I could use a real workshop, this was build in our kitchen and sprayed in my backyard
    tubegeek likes this.
  15. Mistahbrock
    Denmark
  16. gimmeatele
    gimmeatele Tele-Holic
    Alora Spain
    Brilliant job!
  17. Mistahbrock
    Denmark
    Thank you Gimmeatele
    And a nice weekend to everyone ✌️
  18. Ted Keane
    Ted Keane Tele-Meister Gold Supporter
    Westminster,CO
    That's so cool.Really nice work.And thanks for the updates as you went along.
