Highway One Polishing Project
Discussion in 'Finely Finished' started by markw51, Sep 8, 2013.
  1. markw51
    markw51 Tele-Afflicted
    Melbourne, FL. USA
    I decided to put noiseless pickups in my Highway One and since it was going to be taken apart decided also to sand down and polish the matte finish.
    This is small potatoes for many of you guys who build guitars but a first for me.
    Here it is wet sanded down with 800 grit then 2000 grit. Sand until there are no more shiny spots. The finish should be completely dull. Use a sanding block for the flat surfaces. Don't sand too much or you could blow through the finish.
  2. markw51
    Melbourne, FL. USA
    Then polish with Turtle Wax Premium Rubbing compound. It is inexpensive, readily available and does not contain Silicone. I used these polishing pads from Stewmac to apply the rubbing compound. Trying to do it by hand bout wore me out.
    After that I used Guitar Scratch Remover to finish polishing by hand.
  3. markw51
    Melbourne, FL. USA
    Here it is after final polish. Waiting now for the Bill Lawrence pickups to arrive for final assembly.
    Now I consider it sort of a custom Tele with a gloss lacquer finish.
    Also putting on Stewmac compensated saddles and a Fender logo neck plate to finish it off.
  4. TheRumRunner
    TheRumRunner Tele-Afflicted
    TheGreatWhiteNorth
    Looks great, I use the Turtle on old archtop bodies to get rid of years of grime, haze, smoke and general misuse. My 7 year old Highway 1 is starting to wear in nicely, that finish is real thin.
    DW
  5. GigsbyBoyUK
    GigsbyBoyUK Friend of Leo's
    Peterborough, UK
    Every day, 1,000 guitar owners are taking their glossy guitars and knocking back the gloss, and another 1,000 are making their satin guitars glossy. Life is strange at times...
