andrewRneumann
Alright folks, I've come a plateau in my knowledge. I really need some guidance on this one. I'm not a solid state guy. Aside from diodes and Zener diodes, I don't know Peter from Paul or even Mary. But I think I'm going to have to dive in and figure some of this out. Here's my situation...
I have a B+ supply of 400VDC. I want to run the power tube screens (and some other equipment) at approximately 250V. The issue is that I need some regulation of the 250V over a pretty large change in current... I'm estimating 10mA at idle and about 50mA at full drive. I don't need perfect regulation, but I need to keep it above 200V. Obviously a 15K dropping resistor is NOT going to work.
I understand shunt regulation with Zeners. The issue with that is that it's wasting a whole lot of power. If my back of napkin estimates are right, at idle I would be dumping 19W out the window through a large current limiting resistor and a string of 5W Zeners. Doesn't seem like the right answer.
What is the right answer? My reading seems to indicate that a MOSFET is the best solution. Merlin has an interesting voltage follower that I could set up between B+1 and B+2. It utilizes a MOSFET and a BJT (for current protection?). I could copy and paste this design, but I have no idea how to find the right MOSFET and BJT for my needs. Can someone hold my hand and lead me in the right direction?
