High end fizz as distorted notes decay
Discussion in 'Amp Central Station' started by hamfists, Mar 16, 2018.
  1. hamfists
    hamfists Tele-Meister
    ely, cambs, england
    I’m hoping someone’s can help me. I have have been getting some fizzing as the notes decay and I’m not sure if it’s normal or I’m being picky. I’ve tried both of my amps (tone king falcon, excelsior) and a few speakers and tubes buts it’s the same with every thing it’s even there when I plug straight into the falcon.
    Is this normal I use a tele, Strat, gretsch if that helps.
    I’ve read a little online but thought I would on here.
  2. corliss1
    corliss1 Friend of Leo's
    Lansing, MI
    It's hard to understand what you're describing, but if it's doing it with multiple guitars and multiple amps it may be normal? Did you try using a different guitar cable to make sure that isn't causing an issue? Maybe a recording of the sound could be helpful for this question.
    zephyrR1 likes this.
  3. VintageSG
    Yorkshire
    How are the amps set with regard to gain and master volume?.
  4. Georox
    Georox Tele-Afflicted
    The tan house in AZ
    Have your ears checked.
  5. Les Paul lover
    Les Paul lover Tele-Holic
    England
    Do you get your overdrive from your amps or with pedals?
    Overdrive / distortion creates harmonics which are higher in pitch than the notes that created them.
    That said, it's difficult to say if that's what you're experiencing or not.
    On a side note, I assume your action is set reasonnably? (as in not super low?) If the action is too low, and the strings still hit the frets as the note decays, that might be perceived as high end fizz with heavy overdrive / distortion. Just a thought.
  6. hamfists
    ely, cambs, england
    It kind of souls like the speaker is breaking up but it happens at lowing gain. It happens with both amp Overdrive/distortion and pedals but I do only play at low volume.
  7. schmee
    schmee Poster Extraordinaire
    Both amps do it? any kind of pedal in between?
  8. corliss1
    Lansing, MI
    He says tone king falcon and and excelsior
  9. hamfists
    ely, cambs, england
    The pedal chain is - polytune2 - big muff - EQD palisades - EQD gray channel - el capistan- flint. It does it with and without pedals.
  10. hamfists
    ely, cambs, england
    But only distorted not clean
  11. Paulie Walnuts
    Paulie Walnuts Tele-Meister
    Pennsylvania
    I have a similar issue going on but I've noticed its bass related and usually only occurs on my wound strings especially low E and A
  12. J-Flanders
    J-Flanders Tele-Meister
    Flanders
    It's normal. Lots of amps and pedals do it. Most people never notice it for various reasons.
    The two most notorious examples in pedals are the Crowther Hotcake and the Boss Blues Driver.
    It's most noticeable when you have the amp or pedal set for 'edge of breakup'.
    When a note or chord rings/fades out it wavers in and out of clipping which gives you that crackly fizzy decay where the clipping no longer seems part of the sound but seems detached and kinda rides on top.
    It usually means the amp or pedal has a great sounding high(er) gain.
    It's also much more noticeable playing the lower (E, A) strings because their pitch is much more different from the frequencies of the crackle/fizz compared to the higher (b, e) strings where it blends more in.
    There's not much you can really do about it:
    Turn up the gain.
    Buy an other amp...
    Try a different speaker (that doesn't emphasise the crackly/fizzy frequencies as much)
    Change the position of the amp wrt your ears/mic (the crackle/fizz is mostly higher frequencies and those are (very) directional.)
    If it's an open back amp, simply try to play it backwards (face the backside to you)
    Try not to hear it or embrace it as a feature...
    Maybe you haven't noticed yet, but the crackle is usually also there while playing, instead of only when a note or chord rings out.
    Here's a good example of some constant crackle/fizz:
    I love the way it sounds in that video but it would drive me mad when playing myself in the livingroom.
    Here's the opposite (no crackle/fizz whatsoever)
    You'll hear it in many recordings once your ear has tuned in to it.
    Listen to this intro for example :
    I'm dead certain that would crackle and fizz if he'd let some of those chords ring out.
    Here's a very good technical explanation:
    https://wiki.fractalaudio.com/axefx...ackle.2C_sizzle.2C_intermodulation_distortion
