Heyboer TO-22 Blues Jr. question.
Discussion in 'Amp Tech Center' started by MrFrenchy, Aug 15, 2015.
  1. MrFrenchy
    MrFrenchy TDPRI Member
    Calgary
    I've done the Fromel mod with full recap, Billm hi voltage pre-amp mod, presence control mod.
    When I received the Billm TO-22 output transformer the AUX Spkr prewire socket was missing. I'm assuming the the extra yellow wire on the OT is for the auto ohms switching?
    Can it be hooked up like the old one came out and leave the yellow wire unhooked? ( it would be insolated to prevent shorting). Until I receive, or buy a new oitput switch jack.
  2. Wally
    Did the PT come with a diagram for the primary and secondary?
  3. MrFrenchy
    Calgary
    No.
  4. MrFrenchy
    Calgary
    Wires are coloured the same as the original except for the extra yellow wire
  5. mcabe
    mcabe Tele-Meister
    New Jersey, USA
    You probably already figured this out, but the TO-22 has 4 and 8 ohm taps. The stock Blues Jr. transformer only has an 8 ohm tap. I assume the extra wire is the 4 ohm tap for the secondary. You should be able to safely ignore the yellow wire. I would contact billm or allen amps to confirm.
    http://billmaudio.com/wp/?page_id=545
  6. MrFrenchy
    Calgary
    It is what I did. And all is working. Insulated the yellow wire with some heat-shrink tube.
    Sent Billm an email. With no response. I dont really need the 4ohm tap. I'm done with the mods on this amp, got what i wanted out of it.
    What a huge difference! Very happy!
    1999 Blues Junior
    Custom head cab, Fromel mods and recap, Billm high voltage mod, audio tapered master and reverb, presence control, MOD reverb tank, TO22 output tranny, twin mod.
    Jet City 1X12 Cab with Eminence Canabis rex speaker.
  7. String Tree
    String Tree Doctor of Teleocity Ad Free Member
    Up North
    MrFrenchy
    I LIKE that!
    If it isn't asking too much, may we see some pics of what you did under the hood?
    How did you re-position the Tubes?
    ~ ST
  8. mcabe
    mcabe Tele-Meister
    New Jersey, USA
    That is one tricked out Blues Jr! I love the head cab conversion.
  9. MrFrenchy
    Calgary
    Didn't have to! Chassis is laying horizontal instead of vertical.
  10. MrFrenchy
    Calgary
    The trick was to make the reverb tank fit in there!
  11. String Tree
    Up North
    Do the Tubes stick out the back?
  12. MrFrenchy
    Calgary
    Here are the pics of my "Blues Senior"!
    The AXE velcro strap showing is to hold the power cable while in transport.
  13. String Tree
    Up North
    Thanks for the Pics, I am impressed!
    Did you Solder the AC Leads and forgo the Stock, Detachable Power Inlet/Cord set-up?
  14. MrFrenchy
    Calgary
    No, on these older model the power cord is permanent.
  15. jfromel
    jfromel TDPRI Member
    Seattle
    If you ever want to use the 4 ohm tap and ditch the fat switch jack here is how you wire it up.
    This is from a Blues Jr that was upgraded to a Mercury Magnetics transformer with the 4 & 8 ohm tap but the wiring should be the same for the TO-22.
    Basically you need two new jacks a switchraft 12a and 13a, clip the the wires for the fat swith close to the main board and resolder the feedback loop as shown. The fat switch will still work fine from the control panel and now you can run two 8 ohm cabs!
    Great looking head conversion, I am jealous!!!
  16. MrFrenchy
    Calgary
    Ok, that seem simple enough!
    Thanks!
