Help.
Discussion in 'Amp Tech Center' started by RRodgers, Apr 16, 2021.
  1. RRodgers
    RRodgers TDPRI Member
    Union, SC
    I have a orange crush60 pro, and want to plug into a hartke piggyback 60w. How can I make this possible.
  2. RRodgers
    Union, SC
    The orange combo has a speaker out jack, says 1x8ohms, 1×16ohms, or 2×16ohms..
    The hartke piggyback cabinet is unrated.. please help
  3. Telekarster
    Telekarster Tele-Afflicted
    Earth
  4. Lowerleftcoast
    california
    To find the Ohm rating of the speaker cabinet...
    If you have a multi-meter, plug a cord into the speaker cab. Measure the resistance between the tip and sleeve of the cord. The reading should be a little less than the Ohm rating of the speaker. Example: A reading of 6.7 Ohms is a speaker rated for 8 Ohms.
    Telekarster likes this.
  5. printer2
    If you just want to run the Hartke then just disconnect the internal speaker and connect the Hartke.
