Help with tube champ reverb !
Discussion in 'Shock Brother's DIY Amps' started by 53knockoff, Aug 18, 2010.
  1. 53knockoff
    53knockoff TDPRI Member
    Ms
    I have a 70's tube champ without reverb . I also have several solid state amps that have reverb such as princeton model solid state. My question is would it be possible to add a solid state reverb to a tube amp. I know you can add tube reverb but that is very costly. Any suggestions would be appreciated.
    Bcarl
  2. laird
    laird Tele-Holic
    Palm Harbor, FL
    Yes, it's possible. I added foldback reverb to my champ, but as everyone says about foldback reverb, it's not all that great. I wouldn't bother doing it again.
    Adding solid state spring reverb is pretty darn difficult. You'd essentially be building a reverb pedal and stuffing it into the Champ circuit. Considering the amount of effort and reward it'd probably be better to just buy a reverb pedal.
    -Laird
  3. 53knockoff
    Ms
    Thanks Laird ! Appreciate your suggestion.
    Billy
  4. MikeMurray
    MikeMurray Tele-Holic
    South Africa - Pretoria
    There's a fellar on either PPWatt or SEWatt that made a few kits using the Belton reverb module and ran it off the heaters.
  5. Jeru
    Jeru Tele-Holic
    Chicago
    I second the notion that you'd be better off with a pedal.
    JR
  6. Angierc
    Angierc Tele-Meister
    East Texas
    Is there such a thing as a (preferable affordable) real spring reverb pedal? Or even a tube driven spring pedal? I have been wondering.
  7. SamBooka
    SamBooka Tele-Afflicted
    Montreal
    I went the oposite way.
    Built a princeton reverb clone and change the output to SE.. so far so good...
  8. M Fowler
    M Fowler TDPRI Member
    Minnesota
    Sam are you running parallel 6V6's then in SE mode or pentode/triode switch?
