Help with the Keeley/Ross 5-knob comp
Discussion in 'Burnt Fingers DIY Effects' started by Mark the Moose, Mar 27, 2020.
  1. Mark the Moose
    Mark the Moose Tele-Holic
    Erie, CO
    I built a Ross Comp with Keeley mods, 5-knob job, but I'm having troubles. I don't have a schematic, just the stripboard layout from tagboard. It has a blend knob, and the clean side of the circuit works fine. However as I turn the blend knob to the compressed side there's no sound coming through. Now if I crank the clip knob and really strum hard it will suddenly come on crazy loud, then, just as suddenly switch the sound off.
    I've gone over the placement of components several times and knifed the gaps between the copper strips but can't seem to get this right.
    Any suggestions?
  2. awasson
    awasson Poster Extraordinaire Gold Supporter
    Vancouver
    I’d check the jumpers and voids to make sure they’re correct. There are several jumpers that join in the same hole on the right side of the board. I’ve built a lot of Tagboard Effects circuits and it’s usually something like a missed or misplaced jumper that trips me up.
    Also as MAO suggested check the transistor orientations.
