Help with First burst attempt
Discussion in 'Finely Finished' started by BargainHunter, Jun 15, 2021.
  1. BargainHunter
    BargainHunter TDPRI Member
    I’ve built and finished several strats and teles this past year and I have gotten the process down pretty good. For a single color, that is.
    Here’s what I’m wanting to do next:
    Basically, I want to make my own “Jason Isbell signature Tele.” If you aren’t
    familiar with the guitar, his is a 60’s fender Tele, rosewood fretboard, double cream binding, with a 3-tone chocolate burst. (Very dark brown-almost black, red, and the orange color in the center.
    I have also looked at the schecter pt special in burst and love it as well.
    I haven’t decided wether to leave grain open or not. Probably not, as I’m also a huge fan of mirrored finishes. So, This won’t look exactly like either of the guitars I mentioned above.
    Ok, here are my main questions:
    1. Dye, or spray?
    A. If dye, what kind? I’ve watched countless vids with stew Mac, RIT dye, leather dye, etc.
    B. If spray, stew Mac Lacquer and lacquer thinner and tint, or basic rattle cans?
    2. If I’m spraying, should I use the paper/ cardboard cutout method to block paint, or “sideways” angular spraying?
    3. If I’m dying the wood, light to dark or dark to light application order? In other words, start from the outside and move in, or vice versa?
    4. Is there a way to find the colors used on the isbell tele? What names are they called? Is it standard fender colors, or standard industry names?
    I thought I had an idea of what to do, but once I dove into YouTube tutorials, I discovered everyone was doing something different and it thoroughly confused and intimidated me.
    thank you all in advance for your help!
  2. Milspec
    Milspec Poster Extraordinaire
    Nebraska
    I've only done one burst and it was a lot tougher than I expected. I had to strip and re-spray twice to get it looking decent. It was tough enough that I ended up spraying the back of the body solid black.
    I sprayed it like a painter paints...in layers. Base color, then inner ring, outer ring, and blended the contrasts with a make-up sponge.
    Over-all, it turned out pretty good, but I have never tried it again.
    novakane, KelvinS1965 and BryanLB like this.
  3. eallen
    eallen Friend of Leo's
    If you want the grain pattern to show thru you will need to use dye. When it comes to dark or bright colors most dye will fade quite a bit, especially reds, except for trans tint & other metallicized knock offs.
    Burst are for easier to do with a gun due to the adjustability. I see no need for the cutouts with the properly adjusted gun and practice. Bursts are really not rocket science like often assumed. Some of the Jason's look like a basic two color while the one you post is a 3 color using red for the transition.
    I spray the entire top with the light color diluted in intensity a bit so I can sneak up on the color I want. Follow by the 2nd color also diluted a bit and start layering it on with the spray pattern pointed off the edge as you go around with more layers being applied as you work your way out for a darker edge. I apply my red transition color similarly as the last color, but you can also apply it 2nd depending on your preferred look.
    If you are an instagram user JNcolor of the fender custom shop is a great watch for technique. On You Tube, www.youtube.com/user/BlueCollarLife/videos. He bounced in here a handful of times a few months ago.
  4. sleazy pot pie
    sleazy pot pie Tele-Afflicted Gold Supporter
    austin
    Eallen has given solid advice, especially jncolor.
    Doing a translucent burst with spray cans may prove challenging. A gun and compressor would make it easier, especially your first try.
    You can order the colors you need from stewmac, reranch( but they have been out of burst amber for a while) Gracey’s is another option for the right colors.
    However you go about it, it can be done.
    Doing a burst finish is exciting to me. You have an idea in your head and try to see how close you can get.
    I have bob Ross’d a couple of bursts and gotten happy little accidents.
  5. Gevalt
    Gevalt Tele-Meister
    Vancouver, BC
    Make sure you know what direction to spray before you start. Test on scraps with cheap paint. Technique is an art form with this
  6. Freeman Keller
    As you and Eric have both stated, there are basically two ways to do a faded or sunburst finish. The old Gibson method is to STAIN the wood with either water or alcohol based stains, then spray clear over the top. Stains allow you to bring out wood grain such as flame in maple - the grain absorbs the stain at different rates. This mandolin was done with stains directly into the wood
    I will say that this is a very tricky technique and mistakes are hard to correct. You should practice a lot on scraps of exactly the same wood so you find out how YOUR wood absorbs the stain.
    The other way of doing a sunburst is the way Fender and most modern finishers do it (except PRS). The body is pore filled if the wood calls for that, then the colors are sprayed in the finish itself. Usually the amber is applied first, then the red and finally the black/brown. The fading is done by controlling the spray pattern and the concentration of dye in the finish. I find it easiest to spray the instrument flat on its back or top and I both spray across and directly towards the side. With lacquer you are relying on each coat to melt into the previous one to get the transition.
    You can also do both, stain the wood to bring out figure and then add some color to the finish to fade it to the edges.
    You will need to mask the binding either way, do either your staining or apply the burst finish, then pull the mask and scrape the binding. After scraping you apply clear - that will smooth the edges from the masking.
    It is possible to spray a burst with rattle cans altho I've never done it. I would want to use the little nozzles that StewMac sells to get the best possible pattern and I would want to practice a lot. Good luck, have fun.
  7. Mark617
    Mark617 Tele-Meister
    Massachusetts
    My limited experience, dye. You can always sand back and apply to desired color and effect. My first went pretty well. However it was a darker edge burst I went for. My next build will be an LP, my plan is to do a Blue Burst. So there will be multiple colors involved.
    Dive in and have fun. No matter what it’s your build , unique to you.
  8. Vizcaster
    Glen Head, NY
    You won't need a masking template or cardboard for spraying. An airbrush is enough for the job, but of course the manufacturers use larger spray guns. Much depends on what's at your disposal in terms of the equipment.
    Having your own equipment will allow you to mix your own colors which is a ton more versatile and much cheaper than rattle cans. Seal first, then put the color in the finish for what furniture makers call a "toner" or "shader" coat (we call it "burst"). For the dark part don't be afraid to use pigment you can sneak up on opacity faster that way. Whatever finish you use it's likely to be compatible with Trans-Tint (color tone) concentrated dyes or Mixol pigments. Read up on the particular material combination, sometimes it's beneficial to dilute the Transtint into the appropriate solvent before mixing it into the finish. I use water based finishes where it's important to make sure you let the dye/pigment/whatever sit in the finish mixing cup for long enough for all the complex chemicals to get along. Traditional solvent based finishes tend to mix faster.
  9. Sea Devil
    Sea Devil Friend of Leo's
    Brooklyn, NY
    A friend asked me about what I used for a sunburst recently, so I have this pre-written:
    "Mohawk rattlecans. Ultra Classic Toner Natural Pine and Amber, Tone Finish Brown Cherry, Colored Lacquer Black Gloss, and Tone Finish Clear 75-80 sheen, all over yellow stain and sealer. I shot the black from the center out with a Jazzmaster-shaped piece of cardboard over the guitar, and all other tints from the outside inward. Sides got the black from the outside in with the cardboard mask as well."
  10. Danb541
    Danb541 Friend of Leo's
    Oregon
    I did this before the Isbell tele came out but I think it's pretty close. I used woodcraft rattle cans. Touch up solutions.
    https://www.woodcraft.com/products/touchup-awerosol-toner-golden-oak-12oz
    I used Golden Oak, Burnt Umber and I can't recall the more red color but think it might have been java. I can look at the cans when I get home and let you know if you'd like.
    kafka, Controller and FenderLover like this.
  11. Danb541
    Oregon
    This guy sprays a burst the same way I do for the most part. I don't do the real sort bursts like him, I'm more fluid longer strokes but each way works I guess.
    Beebe likes this.
  12. Danb541
    Oregon
    My final product ended up darker around the edges.
    Vizcaster likes this.
  13. BargainHunter
    Thanks for all the replies! I feel a lot better about things now that I have some solid answers/advice.
    I’ll be practicing a lot on scrap woods so I can figure this out.
    I know one thing, this whole process of learning and modifying/finishing guitars has made me learn the art of patience! LOL. I want things done now!
    I learned real quick that thought process leads to a bad product.
    Also, you guys have some beautiful guitars! I hope I can get close to what you guys have shared.
  14. booaloo
    booaloo TDPRI Member
    Michigan
    Danb541 likes this.
  15. Meteorman
    Meteorman Tele-Afflicted
    State College PA
    I dye the base color and spray the bursts.
    Eric described it perfectly - I use an airbrush, spraying out towards the edges from the center.
    I tried the cutout method - it was a complete bust for me
    Danb541 likes this.
  16. Buckocaster51
    Iowa USA
    Admin Post
    i did this one with spray cans.
    Cut out masks that I supported an inch or so off the surface for the red and brown. Yellow went on first.
    On the right a shaded top martin.
    On the left one I built. Finished the top with alcohol based dyes and cotton balls.
    Many ways to skin that cat
    stratisfied and Danb541 like this.
  17. Beebe
    Beebe Tele-Meister
    Atlanta
    Here's one done with rubbing on weld flower ink (yellow) and black walnut husk stain (dark brown). Yellow first over the whole thing, then brown. I blended with damp cloths as I went, sanded back the edges as needed to fade, then yellow over the whole thing. This pic is with one thin coat of shellac over that. IMG_20210605_091110322.jpg
