redhouse_ca
A few years ago I was lucky enough to get a great Esquire style custom. It has a Don Mare Onion 6.8k pup which sounds awesome. This is the first and only hot pup I’ve ever owned and I always wondered if the guitar might be wired so that the tone sits in front on the volume. The reason I wondered this (besides the fact that I am a bit of a knucklehead when it comes to guitar wiring) is that the tone has such a huge impact on overall output volume. I can go from clean to crunchville just by turning up the tone. I finally got around to taking the thing apart to try and figure this out and it doesn’t look like I was correct. It seems the volume sits in front of the tone but I don’t think I fully understand why it sounds the way it does. Sorry in advance about the sloppy sketch, but I’d be grateful if someone could chime in and help me understand this a bit better. Maybe this is just how a good hot pup sounds (and if so, cool) but is there something about the way this is wired that results in this tone knob magic?
Thanks! I started a project parts caster and I want to do something similar but include a neck pup as well (although probably not hot) and id like to use a similar circuit for the bridge pickup but not totally hyperdrive the neck with tone adjustments. Any suggestions for wiring for that would also be much appreciated.
Thanks again!
Thanks again!
