Help wiring my 3-pickup guitar
Discussion in 'Stratocaster Discussion Forum' started by sloan11, Jun 12, 2018.
  1. sloan11
    sloan11 TDPRI Member
    WV
    I have a guitar with 3 strat pickups in it
    I would like to wire it with the electrosocket 6 way switch to add bridge and neck in parallel
    I would also like a mini switch for series switching (neck/mid, mid/bridge I suppose....im told neck/bridge is bad idea)
    Also I want just one volume knob and one time knob.
    Can anyone help me with a diagram or explain how to go about this?
    (And a recommendation for a good quality mini switch would be appreciated!)
    Thanks
  2. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    If you use 3 minitoggles, 2 on/off for neck and bridge pickups, 1 on/off/on for the middle, you could get neck/middle or bridge/middle in series/parallel - all 3 pickups series/parallel - and neck/bridge.
  3. sloan11
    WV
    In conjunction with a 5 way switch? Or...
  4. sloan11
    WV
    Actually I may just like to do a regular 5 way switch and add mini toggles for series neck/ mid and mid/bridge
    Still just 2 knobs [vol tone ]
    Any advice ?
  5. Zepfan
    Horn Lake, MS
    In place of the 5-way.
    awasson likes this.
  6. Zepfan
    Horn Lake, MS
    If you want to keep the 5-way switch, you could add a mini-toggle 2-way on/on DPDT switch for series/parallel on the middle pickup. It would also be better to remove the middle pickup from the tone circuit and run the bridge pickup to a tone.
    awasson likes this.
  7. Mike Simpson
    Gilbert, AZ (PHX)
    Wire it like a standard 5 way strat switch and add a push pull pot or a mini switch to add N+B
