VicenT-Tele
Hello again!
I'm reading a lot about finishing with Tru-Oil. I have chosen Tru-oil for finishing my project (maple neck and alder body) because I don't need machinery and I don't have a place to use spray.
I have seen many publications and I have almost totally convinced how to do it but I can't find any specific information, that's why I'm asking for your help.
The process I will do.
1 - Sand the body and the neck with 240/320/400 grit. Between them I will lightly dampen the wood.
2 - I will stain the body with a Butterscotch water based stain, I will probably do 2 or 3 coats of stain and let it dry.
3 - I will apply tru-oil and sand with 400 grit sandpaper to create a slurry that can close the pores. Once sanded I will remove the excess tru-oil with a cloth rubbing quickly. Leave to dry for 24 hours.
4 - Apply tru-oil and sand with 600 or 1000 grit sandpaper. Once sanded I will remove the excess Tru-oil with a cloth rubbing quickly. Leave to dry for 24 hours.
5 - (this is where I have doubts). I will apply layers of Tru-oil with coffee filter paper. When I apply these layers, which should be thin, should I wait until it is sticky and rub quickly with a clean cloth? Or leave the oil on without wiping with a paper or cloth?
In many construction threads they always talk about thin coats, but do they leave the thin coat or do they remove it with a cloth when it is hardening? I'm not sure about this detail. I understand that if I am looking to build up layers for gloss I won't have to clean the oil, right?
6 - When I get the desired gloss, I will apply one or two coats of 50% Tru-oil with mineral spirits to make it more liquid. 24 hours between coats.
Is this a correct process? The doubt that worries me the most is if I have to remove the oil once applied in thin coats or better to let it accumulate and sand with 2000 grit sandpaper when I have about 8 accumulated.
I want a gloss finish, but not PRS style.
Thank you very much!
