Help to find this pedal... or something similar
Discussion in 'The Stomp Box' started by sloan11, May 29, 2018.
  1. sloan11
    sloan11 TDPRI Member
    WV
    I'm looking for a preamp / modeling type pedal with the following features:
    XLR output (if not XLR, at least stereo),
    Tuner (not the highest priority)
    Fx loop
    Not tube based.
    Speaker sim
    Not super high gain
    Headphone out
    Aux in
    What I would like to be able to do is avoid big multieffects pedals but still be able to go ampless or into my FRFR direct with amp modeling. While still being able to simply pick up my pedalboard and do headphone practicing straight from the board without introducing more gear.
    I've seen some stuff that's pretty close to that description but no exact matches. (Two notes Le Clean is one, tech 21 sansamp blonde/Liverpool deluxe being another)
    Anybody know of anything that fits the bill ?
    (Another idea would be to go with something that has everything except the headphone and AUX and just add something like Carl Martin rockbug at the end but that's another expense and takes up more real estate.... however if anyone knows of a product that could fill the rockbugs role that'd be helpful too)
  2. Obsessed
    Montana
    I'm not sure if this fits your bill, because this is not my strong suit, but take a look at the Palmer PAL-Preamp MKII. Found it on Amazon.
  3. sloan11
    WV
    Ok I'll check it out ... don't recall looking at anything by Palmer. Thanks!
    Obsessed likes this.
  4. Obsessed
    Montana
    I only mention it, because Palmer makes a bunch of stuff in this arena, so if that one isn't quite what you need, look at their other stuff. Hopefully, people will chime in to clarify and help you. Good luck.
    BTW, this is kind of a bump to catch some other readers that could help.;)
  5. Obsessed
    Montana
    Someone here must know more than I do to help this fellow TDPRIer.
  6. sloan11
    WV
    Yes please Help! Thanks for the bumps !
    Also.. upon revisiting that particular device I remembered that I had seen it before. I had read that the actual casing itself was flimsy so that discouraged me from trying it for my needs. Still looking though!
  7. DaveKS
    DaveKS Friend of Leo's
    KS
    Well you see threads like your pop up from time to time, I want my perfect solution. It really doesn't exist in one box, least that I know of.
    Most people usually end up with multiple components. Like say a ethos pre, run that into your fav stereo time based effects and then feed that to device like neunaber iconoclast. Your aux in requirement adds a extra snafu in there, you really almost need a mixer to do that properly.
  8. blackjaw
    blackjaw Tele-Meister
    RI
    Iconoclast? Fits like 90% of your requirements.
  9. Ladida
    Ladida TDPRI Member
    Sweden
    I use the Two Notes Le Clean for a simular purpose, very happy with it.
    It dosnt havet a tuner, and its tube based.
    Why do you want avoid tubes in this case?
