help - signal reduction acts like short
Discussion in 'Tele-Technical' started by chauncie, Oct 20, 2020.
  1. chauncie
    chauncie NEW MEMBER!
    Asheville NC
    I picked up a 90s duo sonic that sounds great, but has problem in the wiring, and it randomly loses signal going out based on movement of the jack cord (or tone pot?) the signal gets cut by ~25% and sounds super thin but still comes thru. I twist the tone nob and move the cord around and it comes back to 100% (acts like a short, but it’s signal loss). I had a shop take a look, and they said everything seemed fine, but replaced the jack as it was very flimsy. and it’s still happening. they said they checked the pots and wiring and all seemed ok, but it isn’t at all. when played clean it so faint I couldn’t even demonstrate it for them. I’m at a loss, any ideas what would cause this?
    Boreas likes this.
  2. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    Here's a start on basic troubleshooting:
    Was the tech able to duplicate the problem?
    Try a different cord?
    Are you plugged directly to the amp?
    Tried a different amp?
    Any recent wiring changes to the guitar?
    Problem same on all pickup selections?
    Problem same in different pot positions?
    Tried banging on the guitar to provoke problem? (cold solder joint)
  3. EsquireBoy
    EsquireBoy Tele-Afflicted
    Paris, France
    Sounds like some of the signal is intermittently bleeding to ground. I'm pretty sure one hot somewhere is slightly touching a grounded part. As @Boreas suggested, it may be the pickup selector. It could have been the jack, but if it's just been replaced and the problem continues, I would look elsewhere.
    Boreas likes this.
  4. wabashslim
    wabashslim Friend of Leo's
    Sonorous Desert
    Could be when everything is stuffed back into the control cavity something is touching something else that isn't evident when the plate is pulled out. Wires around the switch can get scrunched against the contacts. See what happens when you loosen/tighten the plate while plugged in & strumming.
    EsquireBoy likes this.
