Help! Problem w/ lifting saddle on a B5/ashtray bridge tele
Discussion in 'Tele Home Depot' started by gryffsmyth, Nov 29, 2020.
  1. gryffsmyth
    gryffsmyth TDPRI Member
    Brooklyn
    Yea, made a shim from some scrap maple veneer. I think it was about 1mm thick, sanded roughly into a wedge with a leveling beam on the side of my desk. Not sure what angle that makes, trig was not my forte.
    old wrench and Boreas like this.
  2. Boreas
    Boreas Poster Extraordinaire Silver Supporter
    Adirondack Coast, NY
    I would guess between 0.5 and 1.0 degree judging by how far it moved.
    crazydave911 and gryffsmyth like this.
  3. old wrench
    old wrench Friend of Leo's
    corner of walk and don't walk
    Part of the logic behind the Mastery saddles and bridge for a Tele is that you have that downward force concentrated at four points instead of distributed over six points like a vintage Tele.
    Those Mastery saddles are not going to tip up :).
    Great design, but expensive.
    crazydave911, Boreas and gryffsmyth like this.
  4. gryffsmyth
    Brooklyn
    Yea, I just can't stomach the price. I'm sure they're awesome. I also have my eye on a set of those callaham bigsby saddles with the front facing screw heads.... again, so much dough...
    crazydave911 and Boreas like this.
  5. old wrench
    You can modify your own screws by carefully cutting a slot in the end that will take a little flat head screw driver.
    Screw a nut down the shaft of the screw before you cut the slot. Then, when you back the nut off, it will knock down the little burrs left from cutting the slot ;).
    edit: grammer, gramaw, mamaw?
  6. gryffsmyth
    Brooklyn
    bless you sir - made short work of it with a slotting file. brilliant
    crazydave911, old wrench and Boreas like this.
  7. old wrench
    Perfect :)!!!
    That's the way ya do it, money for nothin! ;)
    crazydave911 likes this.
  8. Freeman Keller
    Maple
