Help Please! Wires for pickups
Discussion in 'Tele-Technical' started by Telebean, Sep 22, 2019.
Tags:
  1. Telebean
    Telebean TDPRI Member Silver Supporter
    Hi, I'm in need of some assistance from you experts please! I've got a MIM Player Series tele, and I'm installing an obsidian wire 4-way switch. However the 3 wires (white black and green) from the neck pickup are too short to reach the solderless connectors. So, I'll have to solder after al . Can anyone please recommend/ link me to the right type of wire to use to extend the existing three wires so that they reach please! Huge thanks, TB
  2. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    Nothing special required. It's millivolts.
    Small diameter wire, easy to work with, not bulky. Doesn't even have to match what's there.
    22-28 AWG is just ducky, or is it; Bob's your Uncle.
    Welcome to the forum !
  3. Telebean
    Thank you sir! How do these look to you? Does one seem like a better option than the other?
    https://www.ebay.co.uk/i/1432098502...90516&itm=143209850250&pmt=0&noa=1&pg=2385738
    https://www.amazon.co.uk/Electric-Guitar-Wire-Cable-Bass/dp/B07JG5K5MM
    Thanks again, good to be part of the forum!
  4. Zepfan
    Zepfan Doctor of Teleocity
    Horn Lake, MS
    I always use coaxial wire from audio/visual hook up wire for the shielding.
    And Bob is my uncle.;)
    Telebean likes this.
  5. sjtalon
    You are more than welcome.
    I like the ebay rolls, you can cut whatever length you need, and unlike the amazon ones, not have short useless stubs of wire you'll just throw away.
  6. edvard
    edvard Tele-Afflicted
    Bremerton, WA
    Do you have an old never-to-be-used-again parallel printer cable stuffed in a box somewhere in your basement or shed? Cut that open and you'll have more than enough wire to do whatever you need with pickups, and there's even shielded wires in there if you like.
    As far as soldering goes, well, if you're the type to be swapping pickups and modding electronics in your guitar, I don't think you'll be able to avoid it. I've done the "wire twist and electrical tape" modding method before, and I can tell you from experience that it may last years, or it may last a week. Do yourself a big favor and don't be afraid to solder.
  7. Telebean
    Thank you for your help sir!
  8. Telebean
    Thanks for your encouragement . Now that this project has lead me to soldering, it makes sense to learn how to do it now for future projects!
  9. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Telebean and magic smoke like this.
