Help needed with wood dye like zoot suit.
Discussion in 'Finely Finished' started by KingKara, Aug 22, 2019.
  1. KingKara
    KingKara TDPRI Member
    Tricity
    Hello all,
    I’ve been trying to do a zoot suit LP copy.
    Got myself birch, nice “eco friendly” (but not wallet friendly ;-)) dye ... and got this :)
    A02812E1-03A0-4BB7-A659-B3B17C3B2E54.jpeg 04890F0D-9298-4999-8581-A25FDECA1DE2.jpeg 081A7B0F-7469-421F-A0D0-05B0FE27C7EB.jpeg
    So as You can see my dye of choice has not penetrated the wood. As a result it looks nothing like the original.
    I will appreciate if anyone can help me with correct “stuff” to use for this job.
    Godspeed KingKara
    Matthias, Jim_in_PA and paulblackford like this.
  2. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Those Zoot Suit guitars were built with dyed laminates that were then glued together and cut out.
    I suspect they were pressure dyed just like house deck lumber is pressure treated.
    Or vacuum treated like this pickup, see how much air is pulled out and then wax (or dye) goes deep.
    KingKara likes this.
  3. KingKara
    Tricity
    Thank you for responding jvin248, that seems the most probable way that Gibson used back in the day. Unfortunately impossible do replicate in my modest “factory” ;-)
    Does anybody know alternative that is doable for an amateur like me ? :)
    Godspeed KingKara
  4. steadyriot
    steadyriot Tele-Meister
    Netherlands
    Get pre-dyed skateboard ply's. You can get these colored veneers online from places like roarockit.
    KingKara and Muinarc like this.
  5. paulblackford
    paulblackford Tele-Meister
    Cincinnati
    Not that I think you're wrong that the color saturation is a bit lacking. It does seem a bit pale. However, you should test a sample with some clear coat. A lot of color saturation will be deepened by the clear coat. You might be surprised by how much darker it will get.
  6. paulblackford
    Cincinnati
    Also, you may need to combine coloring methods to get full saturation. Dyes are good to color surfaces. Stains are good for getting into the pores. You might need to combine them to get full color. You would probably have to limit you color choices to those that have both a dye, and a stain. Either that, or use super-saturated aniline dyes, but you have to be careful, and use gloves because they will dye you skin as well.
  7. Mr Green Genes
    Mr Green Genes Tele-Afflicted
    MI
    JVin is right.
  8. Mr Green Genes
    MI
    I'm not sure what you've got going on there, whether the pieces are glued yet, whether you're going to steam bend what you have, or how you're going to use it, but the cheapest, easiest way to reinforce the color would be with Sharpie markers. They come in a surprising array of colors.
  9. KingKara
    Tricity
    Thank you guys for your tips. I might try to combine a dye with stain.
    I also will not scrap existing neck and try to finish it with true oil or clear coat as advised.
    Will get back to you guys with results :)
    Godspeed KingKara
  10. KingKara
    Tricity
    Thank you for the tip but I would like to keep it in diy spirit, also I’ve bought like a ton of birch laminate:-D
    Godspeed KingKara
  11. KingKara
    Tricity
    That would not work as I’m laminating the birch myself from individual layers. First of course I’m dyeing them in 4 different colors. Then cutting out the desired shape, then sanding and more sanding, just like with “normal” wood.
    Godspeed KingKara
  12. Mr Green Genes
    MI
    Ah. In that case, I'd go with a good, long soak (measured in days, not minutes) in aniline dye. No guarantees, but it's worth a try.
  13. Silverface
    Lawndale CA
    Can you post pictures of what you are starting with and the "original"? I don't understand whether you are dying thin sheets and doing your own lamination or trying to dye thin strips in a premade, bare-wood lamination.
    If you are trying to dye strips in a built-up lamination the glues will prevent dye penetration. As previously noted, for full color depth thin laminations like that would need to be be pressure-treated (with color) prior to assembly.
  14. KingKara
    Tricity
    Hello Silverface,
    I start with this
    Then I’m using 4different dies ( here is the black one)
    and after getting few days of drying diet I glue them.
    Here is the thickness:
    Godspeed KingKara
  15. Jim_in_PA
    Jim_in_PA Tele-Meister Ad Free Member
    SE PA near New Hope PA
    Getting color completely through the thin wood veneers like that requires pressure/vacuum techniques to get full saturation...something difficult to achieve in the typical home shop. There are commercial sources for the stuff, but I'm not sure if the lengths required are available or not. I've never checked into it.
  16. Buckocaster51
    Iowa USA
    Admin Post
    What happens if you submerse it in the dye and let it soak?
  17. Muinarc
    Muinarc Tele-Meister
    Arizona
    Here's a picture of the Gibson he's going for in case anyone was wondering what they looked like.
    KingKara and Jim_in_PA like this.
  18. SacDAve
    SacDAve Poster Extraordinaire
    Rocklin Ca.
    I did some experimenting trying to make colored binding, I put the undyed strips of binding into a pipe, caped it off filled it with dye then pumped it with 120 PSI air pressure, within 30 min. I lost 10PSI then pumped it back to 120 then lest it overnight pressure might of dropped a little. I used a water base dye I got good penetration on most the strips Was a mixture of hard and softer woods of course the harder wood dye did not penetrate as much. The other problem I sprayed a strip with water to do some test bends the dye was not stable at all. Most likely any glue would have made the dye run. What I would do next time is try mixing the dye with thinned out lacquer (or something like that) maybe when it dried the dye would be set/stable. I might try some more experiments. thumbnail 1.jpg thumbnail.jpg
  19. Silverface
    Lawndale CA
    Dye work would have to be done prior to glueup.
    Correct.
    1. It's doubtful you would get consistent color, or the color as deep as you're looking for. The dye in a case like this doesn't "color" the wood - it's compressed into and becomes part of the wood. That's the only way to get full color strength...but....
    2...ANY home-applied glue/adhesive will change the colors.
    This type of thing isn't done even in a normal wood finishing shop. It's a very specialized type of application, with a fairly high piece rejection rate. That seriously increases cost, one reason you don't see it very often.
  20. KingKara
    Tricity
    @SacDAve , wow that is really ingenious!
    Just to give some update, as we speak I have a test piece submerged in the aniline dye. I’m going for a quick mountain hike next week so there will be no updates for a while, BUT ! my test piece will be more than 10 days in the dye. So we may have the answer if it’s possible to obtain the Zoot Suit finish with this dye home method.
    Godspeed KingKara
