help needed bullet 3 way 2 pickup wiring
Discussion in 'Squier Tele Forum' started by bls82261, Feb 28, 2020.
  1. bls82261
    bls82261 TDPRI Member
    Virginia
    replacing a box type switch with a crl switch. It came without a diagram. I'm having trouble finding just a simple diagram. If you read the comments on the stew mac sight they sound wrong. Anyone with a straight forward link? Thanks
  2. naomimoan
    naomimoan TDPRI Member
    Jersey
  3. warrent
    warrent Friend of Leo's
    toronto
    CavalierX, casey2910 and naomimoan like this.
  4. bls82261
    Virginia
    Thanks. This is my first time, obviously. Where do I attach the ground wire from bridge that comes off the volume pot? On the box switch it was soldered to frame of switch. Same thing again?
  5. naomimoan
    Jersey
    The ground wire from the bridge should be soldered to the back of the volume pot. If you're just changing the switch I don't see where that wire comes into play...
    LutherBurger and bls82261 like this.
  6. bls82261
    Virginia
    thats what I thought. redundant ?
  7. naomimoan
    Jersey
    maybe the old box switch didn't have continuity to the control plate & it was grounded to the switch frame?
  8. LutherBurger
    LutherBurger Friend of Leo's
    NYC
    Yeah, the switch doesn't need its own ground wire.
  9. bls82261
    Virginia
    I don't know. The ground from the volume pot is not connected. I have power and tone changes in all three positions but have a bad hum across all three positions. What do y'all think?
  10. bls82261
    Virginia
  11. warrent
    toronto
    solder it to the back of the volume pot. (look dead center on the diagram)
  12. warrent
    toronto
    One lug of the volume pot is always grounded to the back of the volume pot. It's the part of the posted diagram where the word solder is. Did you do this?
  13. LutherBurger
    NYC
    It usually goes through a hole in the wood and gets squashed under the bridge plate to ground the bridge and strings. If you haven't removed your bridge or yanked the wire, it's probably still there.
  14. bls82261
    Virginia
    I was getting a little frustrated so I decided to just put everything back together and get a fresh start tomorrow. I tested it after and it sounds perfect now?????? Here is how it was set up with the old switch. It's the black wire that is soldered to the frame of the old switch that is confusing me.
  15. LutherBurger
    NYC
    Where does the other end go? I can't trace it in the photo.
  16. bls82261
    Virginia
    soldered to the volume pot. along with a black wire from bridge pickup and a black wire from the neck pickup. It matches the diagram above but instead of going off into space it was soldered to the old switch frame.
  17. LutherBurger
    NYC
    That's what I hoped. Your bridge ground is a separate wire. You don't need the one that's flappin' in the breeze, and you can cut it off if you like.
  18. bls82261
    Virginia
    Thanks everyone. All seems good. Hum free and solid in all positions.
