HELP: my humbuckers are humming, but not when both are on
Discussion in 'Just Pickups' started by WilburBufferson, Sep 28, 2020.
  1. WilburBufferson
    WilburBufferson Friend of Leo's
    I just installed some Seymour Duncan Antiquity mini humbuckers in a SG -- got it all together tonight but I am hearing hum on the bridge and neck pickups (alone), but the guitar is dead silent in the middle position (both pickups).
    Two-conductor wire, no fancy switches. I followed the diagram from Duncan. All else equal, what are the likely culprits of this noise, or is it possible that they are just "that way," as some humbuckers are? They sound big and full, so I don't think I'm hearing only one coil on either, but I find the hum cancellation in the middle position a bit odd.
    What should I check first? I can send a picture but it's pretty cramped in there!
  2. Jay Jernigan
    Jay Jernigan Tele-Holic Silver Supporter
    10-uh-C
    I would ask Duncan.
  3. Jay Jernigan
    10-uh-C
    After thinking about it, are they two conductor plus shield or only two? If there is a separate shield, it has to be grounded, also.
    I'll shut up now.
  4. WilburBufferson
  5. WilburBufferson
    two conductor...
  6. Ron C
    Ron C Tele-Meister
    Long Island, New York
    Just a hunch but I suspect the switch since it’s good in the middle position. If you don’t have a spare, maybe do a test going straight from neck pickup to volume pot, then repeat with bridge. Good luck!
    Jay Jernigan likes this.
  7. Deepblankspace
    Deepblankspace Tele-Meister
    A shot in the dark is the bridge still grounded? Your saying its quiet in the middle position so it probly isnt what im suggesting.
    I just picked up a guitar that hummed with humbuckers, except when i touched the metal jack plate. Leading me to beleive the bridge and strings are not grounded.
  8. WilburBufferson
    I know what you are referring to, but it isn't that. I bought these on ebay and the seller told me that the antiquities are slightly noisy, just like how they made them back then. Shame, because they otherwise sound good. So, I'm sending them back.
    This is the second high-end Duncan set I have owned that has really disappointed me. I didn't even get into the time I spent getting them set up with spacers and shims so that they would properly fit in my SG. :rolleyes:
